    Cordless Drill
    68 Posts 20 Posters 22.0k Views 20 Watching
    • boofredlayB Offline
      boofredlay
      Thanks Dave. And it seems Jamestown is having a 15% sale so it is the best price I have seen yet.
        Order it now, then.
        You can also get an anchor for your boat while you're at it. And some pine tar and whipping twine and...
          boofredlay
          Hey, do you need Festool driver and drill bits? I notice some are notched. Will standard drill and driver bits work ok?
            I think it'll use the standard driver bits you can get anywhere. Get the keyless chuck, too.
              boofredlay
              Thanks again Dave, and for the phone chat tonight.
              Drill kit ordered [patiently awaiting arrival]
              http://www.freesmileys.org/emoticons/emoticon-tv-002.gif
                It was good to chat. I'm almost as excited as you are to get it.
                  boofredlay
                  Just got an email that it shipped. Fast turn around.
                  http://www.airsoftforum.com/board/style_avatars/Smiley_Avatars/smiley-biggrin.gif
                    Wow! You might have it Monday.
                    • jeff hammondJ Offline
                      fellas.. gonna have to say that's one ugly looking drill πŸ˜‰
                      doesn't have the right ergonomics either.. i don't think you can hold it the right way.
                      to each their own though πŸ˜†
                        Jeff, I've used one and watched a friend use it a lot. Never any problemswith holding it right that I could see.
                          a lot of people actually hold drills in the palm of their hands and use the pinky and ring fingers on the trigger.. (which puts your arm/shoulder/body directly behind the motor and inline with the bit.. ie- way more power and stabilitly)
                          i watched the C12 advertisement:
                          http://video.google.com/videoplay?docid=-5430410674798623774&hl=en#
                          ...and it looks like he's constantly putting his other hand on top of the drill to get the extra power But, that's the same place where the gear shift is so i'm guessing the switch gets changed accidentally.
                          i sort of wish one of these tool companies would do some scientific research on how we actually hold drills and/or how best to design a drill for optimum stability and power.. this gun handle type design has been around forever and surely they didn't get it right on the first try ? πŸ˜„
                          screenshot from the festool video:
                            I use both DeWalt and Milwaukee cordless drills at work nearly every day and have never found the need to hold the drill as you describe. That's just me, though. Doesn't seem like a point worth arguing about since most drills are designed to be triggered with the index or second finger.
                              oh wait, i'm not coming from an argument stance.. just nerding out on drills πŸ˜‰
                              i assume you're doing mainly light duty work if you're comfortable holding the drills like that..
                              my crew doesn't do too much heavy duty drilling but we do use a lot of 3" screws (as in 10000 of them for a two week job) as well as boring up to 1/2" holes in 1/4" steel.
                              if we held the drills as they're designed to be held, our wrists would break off.. (as it's the wrist that has to make the weird angular change of force from your shoulder to the actual bit.. as shown in the picture above)
                              anyway, i (and much of the construction industry) am now using an impact driver for the long screws (i'm pretty sure i linked to one last year in this thread).. those things do so much of the work for you that you can hold it pistol style with only one hand and drive 3" screws..
                              [edit -- well, two years ago.. http://forums.sketchucation.com/viewtopic.php?p=53520#p53520 ]
                              for boring holes, we use a certain dewalt corded drill that fits comfortably in the palm of your hand.. even has a little groove for your thumb to rest.. i'm pretty sure the design was accidental but it works out great.
                              • dermotcollD Offline
                                dermotcoll
                                Hi Boo
                                Sorry I missed the return of this post, I was offline for a few days. You asked about the chuck. The attached pictures show you the set I have got when I purchased my C12. This was not the standard set but was on offer at the time. The right angles chuck and the offset chuck have been absolutely brilliant for fitting kitchens. You can get a screw in anywhere with this kit - right into the corner of a unit or you can screw cornice down onto the tops of units very close to the ceiling. The standard kit comes with the keyless chuck and the centrotec chuck, the latter will not accept standard hex bits - which can be a bit annoying but I have the centrotec bit set as well so it doesnt affect me too much. I hope this helps and enjoy the new toy - it is a great piece of kit.
                                When you burn your arse - you gotta sit on the blisters!!
                                  MtnTrails
                                  I'm late to the party as well... The centrotec holder will NOT hold anything that doesn't come from Festool. Standard bits like you'd buy at one of the big box stores won't fit unless you take a belt sander to 'em, and even then the groove is in the wrong place for them to lock into the chuck. I honestly don't remember if a bit holder comes with the kit, but the BHS 65 holds standard sized short driver bits. Problem solved 😎 If you don't get one with your new drill, Festool's part # is 492 539. I think you're gonna like it Boo!
                                  -Brian
                                  Keep doing what you're doing and you'll keep getting what you're getting.
                                    boofredlay
                                    Thanks.
                                    It came in on Wednesday and I was not able to open the box until yesterday. I got the whole kit like Dermot shows.
                                    Batteries charged and ready for action... I think I have a fence that needs fixing.
                                      Cool! How could you hold off on opening that box?
                                        boofredlay
                                        Trust me it was real hard. I had a bunch of work to do and for two nights did not get to bed until after midnight.
                                          You shouldn't be on the computer today, then. You should be out making like a woodpecker on your fence. πŸ˜„
                                            boofredlay
                                            But it was break time with a glass of ice water in my other hand. It topped out at 98 before the skies let loose and our house, then later on the road my truck, almost got hit by lightning. 😲
                                            • 3 / 4
