    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Deleting internal faces/edges
    10 Posts 2 Posters 3.3k Views 2 Watching
    • E Offline
      evan3585
      I'm somewhat new to sketchup and I have a model from a gamecube game I ripped and I need to take some of the faces from the inside of the model out but when I do it deletes the whole face from the inside and out of the model. I can't figure out how to divide a face and just delete the part I want. I need to make this model with no random faces cus I'm going to use Pepakura Designer to make a papercraft out of it.
        d12dozr
        Trace around the part you need to delete to divide the face. Does that help? If not, post a picture so we can see what you need...
        http://goo.gl/f7ooYh
        • E Offline
          evan3585
          Heres a photo. Not sure what you mean.
          http://img5.imageshack.us/img5/5015/help1ih.jpg
          I tried using the line tool to divide it but it doesnt work right. Even when I do manage to get that part deleted the edge is still there and when I delete that the whole piece deletes.
            d12dozr
            I see...just select that face you want to delete, then right click > "Intersect with model". That should divide the face so you can delete it (as long as the intersecting pieces are not in a separate group)
            See this video to understand better:
            YouTube - Google SketchUp Techniques: Intersect with Model
            [flash=480,385:a4p46rxg]http://www.youtube.com/v/Ax9HY06PB8M?fs=1&hl=en_US[/flash:a4p46rxg]
            Does that help?
            • E Offline
              evan3585
              Thanks so much:) Learning that Intersecting is what I really needed to know.
                d12dozr
                You're welcome...glad that helped πŸ˜„
                • E Offline
                  evan3585
                  Ran into a problem. I was able to intersect simple shapes but my complex model after I intersect deletes some faces. Don't know why? I made sure the objects was exploded then I highlighted everything with Ctrl + A then right click and intersect with model. Theres missing faces that just delete out of knowwhere. Please help thanks:)
                    d12dozr
                    That might be happening if the faces are very small...the workaround is to scale the model x10 or x100, perform the intersection, then scale back down.
                    • E Offline
                      evan3585
                      Thanks! That did. One last thing how do I scale back? type -10 if I typed 10x?
                        d12dozr
                        type .1
