    Podium interiors
    6 Posts 6 Posters 955 Views 6 Watching
      julieross
      Hello this is my first attempt at some interiors using Podium. I am still getting some "hotspots" and can't seem to find a way to get rid of them. Is post production the only way?? I am still learning so any comments/crits or advice is greatly appreciated.
      • EdsonE Offline
        Edson
        hi julie,
        they are quite good already. I bet you are using V2.
        about the hotspots, in v1.7 they will go away if you use the best presets (quality and noisy). probably, it is the same in V2; in this case you should try using the interior_high or the interior_QMC presets. I hope it helps.
        http://www.mahfuz.arq.br
          twinkle
          HI!
          your images are really good... what materials did you use and what shadow and podium settings? I am getting grey walls even with white coloured materials and the rendered images become very dark.
          Please suggest...
          • dermotcollD Offline
            dermotcoll
            Very impressive for first attempt. Well done Julie! πŸ‘ πŸ‘
            When you burn your arse - you gotta sit on the blisters!!
            • rohallorahR Offline
              rohallorah
              WOW!! Didnt know you could get such great results with Podium (VRAY user myself) Looks great!! Well done!! πŸ‘
              Robert O'Halloran
              "Interior Architect & Designer"
              http://designermedia.ie
                Ross Macintosh
                Great modelling Julie and nice results with Podium!
                I see the light 'hotspots' in two of the images. Must be a real bummer for you to get those when otherwise your results are so great.
                Regards, Ross
