Export PNG with Transparent Background?
Can it be done? What is the easiest way?
It can be done with SU on the Mac only.
I see you have pro however so you can send the model to LayOut and from there, you can export a png with transparent background. Make sure however to turn off sky and ground first in your Styles dialog > > In model Edit > Background settings.
If you make scenes (and save / update this style in SU with them), you can get the same scenes back in LO.
Also, from LO you can export much bigger images.
