    Match photo + Vray :(
    6 Posts 5 Posters 4.5k Views 5 Watching
      dalaylama
      Hi all,
      Here's is my first real post, please apologize for my grammar , english isn't my first language.
      The problem: When using the SU match photo tool with VR rendering the picture doesn't fit the picture perspective and the photo doesn't show at all
      My question: is it possible to use SU match photo tool and Vray render engine. Because from what i see the VR engine is changing the perspective i use from match photo option .Also it is not applying any part of my photo when rendering. Is there an easy way to do or do i have to aproximatly render a scene and try to photomatchit in PShop??? BTW am using SU pro 7 and latest VR version available.
      Thank you
      Good day to you all
        Rob D
        Hi. This should work. Can you post an example skp file so I can take a look?
        Your grammar is better than 99% of native English speakers by the way ๐Ÿ˜„
        • dcauldwellD Offline
          dcauldwell
          dalayama
          There are a number of threads on the ASGVIS forum site (http://forum.asgvis.com/index.php?action=forum) about photomatching.
          Photomatching can mean a number of things. Personally I just use it to set up the viewpoint etc of a model, but I don't 'project' the textures.
          (I merge the finished render with the photo in a photoshop type program)
          If you have 'projected' the textures onto your model then to get vray to render them you will need to select each face with a texture on it and 'make texture unique' - vray will then render it correctly.
          David
          Sketchup 2017
          (vray 2.00)
            dalaylama
            Thank you both for your anwsers,
            So heres an exemple of what i would like to render with the match photo option(this isn't the real picture but i think you get the point:D) ,but side by side with the vray engine.
            Exemple to be render
            But that what it give's me instead
            render with vray deafault setting and a physical camera
            No background and not the same perspective.
            So my question is: Am I doing it right or should i try something else
            Btw David i read a lot of your post on the ASGVIS forum and on this one, they gave me a lot of tips for easier and better rendering.
            Thank you again
            Joรซl
              davide.skp
              dalaylama look at this.
              http://forum.asgvis.com/index.php?topic=9115.0
                mailandrex
                i need to see that link T.T how can i do
                hollywoodboy_xoxo
