    MODO 401 thread
    extensions
    33 Posts 12 Posters 18.4k Views 12 Watching
    • K
      kwistenbiebel
      Thanks Sepo for the links to the tutorials. They are a big help.
      I am looking into Modo as a second rendering option, especially for architectural animation.
      My question would be : does Modo allow for moving cars, animated people textures, water effects etc...?
      • K
        kwistenbiebel
        Thanks stinkie!
        If I am reading correctly between the lines, exporting from SU as .obj will not hold the materials in Modo. Correct?
        (because Sketchup doesn't write a .mtl file next to the .obj together with a textures folder)
        Off topic but not really : why doesn't SU write that .mtl file? Could someone write a script for that?
        • tbdT
          tbd
          kwistenbiebel: tried http://www.idevgames.com/forum/showthread.php?t=13513 ?
          http://plugins.ro
          • K
            kwistenbiebel
            Hey, thanks Tavi! 👍 Great link.
            [EDIT]: Unfortunately the SU2OBJ ruby doesn't work. It shows up in the plugins list but when you click on it, nothing happens (SU6)
            Any suggestions?
            • tbdT
              tbd
              works for me the obj export. though i was unable to get with textures in Modo.
              any errors in Ruby console when clicking on Plugins menu item ?
              http://plugins.ro
              • EarthMoverE
                EarthMover
                Materials import fine into Modo using the standard .obj option. You will usually just get a prompt to find the path associated with the materials and then it pulls them all in.
                Has anyone tried going the other direction? Modo > SU? I wanted to model some pillows in Modo and then bring them back into sketchup, but there is no .3ds export out of Modo. I guess I could go .obj, then take it into another program (i.e. Max, Silo or DE) to convert to .3ds, but I thought there had to be an easier way.
                Content Creator at Skapeup
                  sepo
                  I thought it strange that there is no .3ds export. I supose .obj and using third party converter or using importer made by Jim Foltz ( I thinkI am correct). I remember reading about it. I have not tried it so I do not know how good it is.
                  • EarthMoverE
                    EarthMover
                    What's up with Modo's memory usage? I'm trying to take a project into Modo for rendering and some modeling tweaks, but I'm ready to give up. I've had at least 5 crashes and Modo is just hogging all my systems memory. I'm running on my laptop, with 4GB DDR3 and a GeForce Cuda 9800 M GTS video card with a GB of dedicated video memory and Modo is hogging it all. Subsequently, I've opened the same exact file, at the same time in 3DS Max and it's running flawlessly and using about 10% of the memory that Modo is using. I'm ready to give up on Modo for this project and it's back to Max for me.
                    • StinkieS
                      Stinkie
                      It may be best to post your specs and screenies of your settings on the Lux forum.
                        AcesHigh
                        people, check this thread by Andeciuala... he is importing Sketchup models directly into MODO 401 (As seen on 1:44 of his video, where it shows MODO 401 recognizing all Sketchup files)!!! 😮
                        http://forums.sketchucation.com/viewtopic.php?f=81&t=29011&p=259176#p259176
                        • 2 / 2
