    Coffee Tables
    7 Posts 5 Posters 1.6k Views 5 Watching
      dylan
      I was searching a few furniture sites this weekend and saw a few things I liked.
      Whilst having a spare hour I modelled two tables.
      These are not modelled for efficiency, I used the 30minute challenge rules to model as quick as possible to get some practice.
      The colourful one has a lot of rounded edges and high sided arcs. Could look nice rendered!
      The wooden one is very basic and in my haste to model it I forgot to increase the arcs sides, hence the visible straight edges on the curve.
      I can quickly re-model this should anyone want a better version.
      Funky Table One.skp
      Coffee Table One.skp
      http://dmdarchitecture.co.uk/
      • W
        watkins
        Dear Dylan,
        Here's one for you to model
        403 Forbidden
        (www.dylangold.com)
        Regards,
        Bob
          dylan
          I like that a lot Bob, good find!
          I will model that one tomorrow when I get a free 30 mins.
          • olisheaO
            olishea
            cheers for sharing I like the simple one.
            oli
            • boofredlayB
              boofredlay
              Nice work. I like that first one quite a bit.
              • W
                watkins
                Not a coffee table, but a table based on the image here:
                http://www.ronaldemettfurniture.com/
                There are no images to show how the designer coped with the curved legs on the underside of the table, and so that bit is probably all wrong. I cannot quite determine (from the image) if the inner legs curve inward towards the centre of the table, or lie in same plane as the outer legs. I made them curve inward. I scaled the image to make Ronald Emett 5' 10" tall, and then used the tape-measure tool measure critical dimensions. I used the golden rectangle ratio to determine the width of the table from an assumed/guesstimated 1400 mm length.
                regards
                church table.skp
                • C
                  cheffey
                  Here is that Cornered Table or a version of it. I'm not sure the dimensions are right but I took a shot at it.
                  cornered table.skp
                  BROS RŌMAN BRÄUN
