    Checking for users viewport settings?
    8 Posts 4 Posters 589 Views 4 Watching
      tomot
      A particular Ruby script I'm presently writing, assumes the user is in plan view, when he/she uses my script.
      Is there a code snippet that I can add to my script, that does the following:
      checks the current viewport setting, and re-orients if necessary the users viewport to a plan view , prior to activating the rest of my Ruby script?
      my plugins
      tomot
        Look at http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#send_action
        Sketchup.send_action(xxx)
        where xxx==
        "viewTop:"
        and then perhaps
        "viewZoomExtents:"
        or
        "viewZoomToSelection:"
        and probably before the zoom
        model.active_view.camera.perspective=false ###(if model.active_view.camera.perspective?)
        πŸ€“
        • Chris FullmerC Offline
          You would want to check the vector of the camera direction. In plan view, it should be 0,0,-1. This snippet can be run from the web console:
          model = Sketchup.active_model view = model.active_view cam = view.camera if cam.direction.normalize.inspect == (Geom::Vector3d.new 0,0,-1).inspect UI.messagebox "Plan view already!" else Sketchup.send_action("viewTop:") end
          Thanks to TIG for the send_action idea. I rarely think about those things, and it simplified setting the top view camera significantly.
            tomot
            I was also doing some more digging into TIG's Stuff πŸ˜„ I modified the axo+iso.rb to include a plan option
            (a lot of coding to get the same desired effect) ...... thanks for the input πŸŽ‰
            def plan
              model=Sketchup.active_model
              model.start_operation("plan")
              view=model.active_view
              camera=view.camera
              eye=Geom;;Point3d.new(0.0,0.0,1.0)
              target=Geom;;Point3d.new(0.0,0.0,0.0)
              up=Geom;;Vector3d.new(0.0, 0.1, 0.1)
              perspective=false
              newcamera=Sketchup;;Camera.new(eye,target,up,perspective)
              view.camera=newcamera
              Sketchup.send_action("viewZoomExtents;")
              puts
              model.commit_operation
            my plugins
            tomot
            • Dan RathbunD Offline
              Dan Rathbun
              No need to slow things by doing String comparison.
              Remember SU defines extensions to the Ruby Array base class, so they are Comparable with Sketchup::Point3d and Sketchup::Vector3d class objects.
              as in:
              cam.direction.normalize==[0,0,-1]
              returns true if normalized camera direction vector is vertical and in the negative (down) direction.
              I'm not here much anymore.
                Good to know Dan. I was not getting the vector object to compare to an array (user error I'm sure), which is why I added the inspect. I didn't quite realize that inspect would return a string. I'll keep that in mind.
                  Dan Rathbun
                  I was not getting the vector object to compare to an array (user error I'm sure), ...
                  for the Ruby Array literal. Get's confusing when your coding in Js, Ruby, etc etc and the same time.
                    My approach avoids the confusion of vectors, eye, target etc... Just use the API functions to set a plan view and zoom to what you want to see, switching off perspective as needed... πŸ˜•
