    Various rendering choices? -- Challenge!
    108 Posts 27 Posters 19.8k Views 27 Watching
      liam887
      well the render turned out very grainy so i dirtied it up a bit in photoshop so it looked like I had intended it to look like that lol, ive been messing about fir the past hour with the settings and ive put another render in but looks like it will be an overnight job as its only on 4% ray tracing! ill post the results tomorrow night fingers crossed they will come out ok, ive also put depth of field in but its really slowing the render down 😞
      VISIT MY ONLINE GALLERY
      • TaffGochT Offline
        TaffGoch
        Liam,
        I like the "illustration" qualities of the second image.
        [EDIT: I hope that Starfleet shipyard is on an asteroid! (No gravity to contend with.) ]
        -Taff
        "Information is not knowledge." -- Albert Einstein
        • TaffGochT Offline
          TaffGoch
          Working with Kerky camera f-stop settings ("Scene> Camera" menu,) I eventually got the amount of depth-of-field blur that I was seeking:
          f/3.5
          Compared to the original:
          Initial render
          Yeesh, this is a lot more time-consuming than looking through a camera stopped-down viewfinder!
          -Taff
          • boofredlayB Offline
            boofredlay
            Here is another angle. I used the same lighting setup as the last one, changed the material to green gum and added a beige backdrop. I also changed the Camera F-Number to 22.
            • TaffGochT Offline
              TaffGoch
              Wait, wait, wait... πŸ˜•
              I thought that higher f-stop provides greater depth-of-field. Wouldn't f/22 give you a large range of in-focus detail?
              Are you positioning the camera right up against the sphere?
              -Taff
                boofredlay
                Yes and yes. I put the camera almost dead on the sphere. I had to change the F stop to a larger number otherwise it was too blurry. On the previous one I did the camera was farther away.
                • TaffGochT Offline
                  TaffGoch
                  Thanks, Eric.
                  I'm glad I have some photography experience under my belt, otherwise, I wouldn't even have been able to guess. πŸ˜‰
                  My test renders have been with the camera at greater distance, with 135mm "lens" to reduce perspective distortion. (I assume you're using the "standard" 25mm lens.)
                  My last render, with which I am delighted, took a lot longer to render. I assume this is processing "overhead," due to the out-of-focus regions. I note that the anti-aliasing time went WAY up.
                  From the Kerkythea console:
                  Ray Tracing (13839 seconds) -- 3 hr, 50 min, 39 sec
                  Antialiasing (23945 seconds) -- 6 hr, 39 min, 5 sec
                  Finished in 10 hours, 29 minutes and 47 seconds
                  (Render settings: 1200x1200 pixels, preset "16. Path Tracing - High + AA 0.3")
                  Thanks, again, Eric, for your help & contributions.
                  -Taff
                  • TaffGochT Offline
                    TaffGoch
                    I've seen a stereoscopic SU/GE model of Machu Picchu (within this forum,) but haven't seen any stereoscopic renderings.
                    Has anyone pursued stereo rendering? (I'm thinking this model should make a good subject.)
                    -Taff
                    • U Offline
                      Unkr3at1v
                      Just a try for a quick benchmark test of my father's new PC!
                      A quick studio setup with two rectangle lights.
                      Took about 40 min (800*x) in vray. Thought it would be faster.
                      Tomorrow I will try a glass material. That will give some nice caustics.
                      Also tried Jade, but I can't get that damn translucency thing to work in Vray.
                      Greetz, Fritz
                      'To Start Press Any Key'. Where's the ANY key?
                      http://www.youtube.com/user/unkr3at1v
                        boofredlay
                        Nice reflections.
                        • N Offline
                          notareal
                          @taffgoch said:
                          Thanks, Eric.
                          -Taff
                          If you have simple lighting in KT (like one or two lights) then path tracing progressive might be the best option. Biased rendering will loose it's advantage when scene complexity rises and you use higher photon mapping options... For complex lighting MLT or MLT/BPT are better options. If you using HDR sky for lighting (and emitters), MLT might be the best option.
                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                          • TaffGochT Offline
                            TaffGoch
                            Thanks, notareal,
                            That is great to know, as I haven't previously seen any recommendations about which render mode is best, under various scene conditions. KT has so many options, any tips/tricks are highly beneficial. If you've got any other such tips, or can reference KT webpage/forum URLs for such, I'd love to hear about 'em.
                            -Taff
                            • N Offline
                              notareal
                              Tutorials master list is a good starting point and not to forget forum search πŸ˜‰
                              • TaffGochT Offline
                                TaffGoch
                                Thanks, notareal, for the tutorial links. Now, all I need is a few weeks/months to read & apply it all.
                                My last render pleases me above all my previous renders. The more I stare at it, the more three-dimensional it looks. (Who needs those fancy 3D goggles, anyway!)
                                http://i579.photobucket.com/albums/ss233/taffgoch/Weave_Toned_Silver_f35-1.jpg
                                What a great program Kerkythea is, and what great help and inspirational ideas you guys provided.
                                -Taff
                                • Chris FullmerC Offline
                                  Looks good Taff. I can't get my eyes to uncross....but oh well. It probably looks better than how my face used to look 😲
                                  • TaffGochT Offline
                                    TaffGoch
                                    Stereo: View cross-eyed
                                    Initial experiment with KT stereo-image production. View by crossing your eyes, until the two images superimpose in the center. (It will look like 3 images in-a-row.) Concentrate on the center image, until it comes into focus.
                                    I used SketchUp to produce two "scenes," which merge into KT as two cameras. (Getting the spacing is tricky. You don't want to overdo the angular separation. It is supposed to mimic the angular separation of your eyes, so camera distance is also a factor.)
                                    -Taff
                                    • daleD Offline
                                      dale
                                      @taffgoch said:
                                      [attachment=0:31w8a5i7]<!-- ia0 -->Stereo_Weave_01.png<!-- ia0 -->[/attachment:31w8a5i7]
                                      -Taff
                                      I find a few beer works well too! πŸ˜„
                                      • olisheaO Offline
                                        olishea
                                        that stereo view is amazing!! looks like avatar!!
                                        seriously impressive but my eyes hurt!
                                        oli
                                        • N Offline
                                          notareal
                                          Lucky you! I think I have some wiring problems - I never been able to see these kind of "3D" images. No matter how much I try to focus... de-focus or what ever. But different 3D glasses do usually work fine.
                                          • olisheaO Offline
                                            olishea
                                            you have to move your head back and forward to get the "focal length" right lol it really does look 3D!!
                                            oli
                                            • 5 / 6
