    [WIP] Reconstruction of my favorite disco Palladium New York
    51 Posts 12 Posters 18.8k Views 11 Watching
    • Mike LuceyM
      Mike Lucey
      Looking forward to seeing what you do with it Jo. Enjoy your holiday πŸ‘
      • jo-keJ
        jo-ke
        I'm back and I'm going to continue that project.
        Here's what I'm going to remodel: The Palladium club was located in New York, it was an old theatre, which was reconstructed in the mid 80ties to a big nightclub, with one of the best lightshows i have seen so far. The backside of the stage was painted by keith haring. It was pulled down in 1998 make place for a new building. here are some pictures and videos of the original:
        http://www.youtube.com/watch?v=t5_NI2MSmp8
        http://www.youtube.com/watch?v=TL6gP90DMi0&feature=related
        https://youtu.be/N8EDo2avdJo?si=-4G9SsfnF4uUJR1c
        http://www.zz7.de
        • jo-keJ
          jo-ke
          here are the first two twilight- renders (with some trange results)
          http://www.zz7.de
          • olisheaO
            olishea
            jo-ke: how come you don't post on twilight forum? you'd get much more direct help.
            oli
            • jo-keJ
              jo-ke
              This is a good idea. I will do that in addition.
              here's a small render took 3 hours with preset low
              http://www.zz7.de
              • olisheaO
                olishea
                I would suggest sorting out your lighting/gobo projections first before using the fog material. it really really slows down render time so use it right at the end.
                like the silhouettes! looking good
                oli
                • jo-keJ
                  jo-ke
                  what do you mean by "sorting"? At the moment the beams doesn't work anymore. I added some other lights to the scene, I don't know what happend but the "fogbeams" doesn't render anymore.
                  http://www.zz7.de
                  • olisheaO
                    olishea
                    I mean making sure the rest of the lighting works before you play with beams.
                    With a fog material the camera must be outside the" fog box" or it won't render (for bias) and the camera must be inside the fog box for unbias (progressive presets)
                    oli
                    • jo-keJ
                      jo-ke
                      I was using preset low and the camera was definitely outside the fogbeams.
                      I have an older version and the render in the same position still works, but not at the new verson.
                      here's another one without beam (but with preset 11, so I expected no beams)
                      http://www.zz7.de
                      • jo-keJ
                        jo-ke
                        a small render after 4 and a half hours with preset low.
                        I think I make the big one, when I'm out...
                        http://www.zz7.de
                        • Bryan KB
                          Looking good!
                          • jo-keJ
                            jo-ke
                            my notebook has rendered all nicht long. here's the result
                            http://www.zz7.de
                            • jo-keJ
                              jo-ke
                              here's another one:
                              http://www.zz7.de
                              • Bryan KB
                                I'd say you've captured the nightclub look perfectly. Which is not an easy thing to do with so many lights and odd shadows.
                                • jo-keJ
                                  jo-ke
                                  yesterday I rebuild the famous stairs with the lights. I rendered the scene again in twilight with preset low for 12 hours. I don't know what happend but the beams weren't rendered right to the end.
                                  http://www.zz7.de
                                  • jo-keJ
                                    jo-ke
                                    same scene, preset 10 for 6 houres without volumetrics
                                    http://www.zz7.de
                                    • jo-keJ
                                      jo-ke
                                      at the moment I'm working on an update of this old project:
                                      first test render
                                      http://www.zz7.de
                                      • jo-keJ
                                        jo-ke
                                        update
                                        http://www.zz7.de
                                        • jo-keJ
                                          jo-ke
                                          another view:
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            one more
                                            http://www.zz7.de
                                            • 1 / 3
