    Various rendering choices? -- Challenge!
    108 Posts 27 Posters 23.7k Views 27 Watching
    • TaffGochT Offline
      TaffGoch
      @solo said:
      I smell a render challenge.... 👍
      Frigging cool model, curious how it was made.
      Your wish is granted...
      I included hidden layers in the model, to demonstrate the development of the sinusoidal "Follow me" path. The methods are conceptually simple, and radial symmetries permit copies of components, so it's not as complex as it first appears.
      BTW, you may consider yourself challenged....
      -Taff
      "Information is not knowledge." -- Albert Einstein
      • TaffGochT Offline
        TaffGoch
        @gaieus said:
        There are some other, interesting layers in there...
        Indeed! Extreme "lensing" magnification, by that orb.
        Nice resultant caustics, too.
        -Taff
          KarinaGM
          The material uses thin film interference for color and fairly simple studio with HDR.
          You mean you used thin film and nothing else? 😲
          well, that HDRI must be a good one.
          **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
          -Benjamín Franklin.**
          • boofredlayB Offline
            boofredlay
            Twilight Render. Progressive, 175 passes.
            Iridescent Coated Aluminum material, two spot lights.
            • soloS Offline
              It must be a guy thing... we love rendering balls.
                boofredlay
                And mine is blue. 😄
                  Ah, nice trick indeed. MLT is "best" when there is (are) enough light(s). In some really shady areas it can get clear really slowly.
                  • TaffGochT Offline
                    TaffGoch
                    Gai,
                    I liked your iridescent render enough to give it a try, using Kerkythea, Metals_Ashikhmin_MLT, rainbow_metal_02, (M)etropolis(L)ight(T)ransfer (for a couple of hours):
                    http://i579.photobucket.com/albums/ss233/taffgoch/WeaveIridescent.jpg
                    Actually, I only used the resultant iridescent colors, saturated and layered, in Photoshop, to "colorize" a greyscale version of my original gold render. (Much faster than waiting for a long MLT render.)
                    [ My new wallpaper! ]
                    -Taff
                      boofredlay
                      Here is another angle.
                      • olisheaO Offline
                        olishea
                        like this one A LOT!! 👍
                        oli
                          +1 👍
                            boofredlay
                            😄 Thanks.
                            • TaffGochT Offline
                              TaffGoch
                              Boof,
                              Can you dish out some details?
                              (I'm still learning materials, but need to move on to depth-of-field, etc.)
                              -Taff
                                Thanks for sharing the settings Eric 👍
                                This is a great learning thread, much appreciated.
                                  boofredlay
                                  Sure. That last one was a metal texture in the Twilight Library called Aluminum NK. Part of the NK Metals.
                                  The rendering was an overnight shot, 10 hours I think, using a progressive setting called Metropolis Light Transport (BPT).
                                  All I did was open your model, click the face with the material eyedropper. Found the Aluminum NK and applied it. I then set the camera focal point inside the sphere and set the camera F number to 8.
                                  Finally I set the render size and progressive setting then hit render and went to bed. That simple.
                                  Edit. Oops I forgot. I placed 3 spot lights in the scene as well. One to the left, one to the right and one below. Each was a separate color. And I set the background color to black.
                                  • TaffGochT Offline
                                    TaffGoch
                                    Indeed, thanks for the settings.
                                    I'm testing a render, right now, using f/5.6, focused just beneath the "surface" of the sphere. This will be my first fray into camera settings, so I'm still a newbie (even though I used to do this sort of stuff with POV, 15-years ago.)
                                    It looks like the Twilight interface makes things a bit easier (rather than just using KT.)
                                    Thanks again,
                                    Taff
                                    • N Offline
                                      notareal
                                      btw if you are looking thin film interference like effect for KT, you can find a procedural texture, mIridescent, in Procedural Textures by Chris Hegarty (Windows).
                                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                        BTW Taff, a little OT but as far as I remember, this was also one of your models:
                                        http://lh4.ggpht.com/_zcvsIuYiVbo/SxpNB9vm88I/AAAAAAAAC2k/VHUGFptgzao/grademål.jpg
                                        Of which I made this simple render first:
                                        http://lh5.ggpht.com/_zcvsIuYiVbo/SxpaUnwolNI/AAAAAAAAC3g/Bvu5aJdcYnU/grademal.jpg
                                        then this one with a glass dome:
                                        http://lh4.ggpht.com/_zcvsIuYiVbo/SxpaQYN4YhI/AAAAAAAAC3c/w7ZuLrnHCt4/example2.jpg
                                        (This was for a help forum discussion as far as I remember although the OP never came back)
                                        • TaffGochT Offline
                                          TaffGoch
                                          @gaieus said:
                                          "BTW Taff, a little OT but as far as I remember, this was also one of your models..."
                                          Gai,
                                          I recall that discussion, and those images you posted. I probably didn't join in, since I've only recently started rendering (again.)
                                          From my past experience with POV, I already knew that rendering is addictive. I was too busy with other projects, and couldn't justify time spent rendering. (Actually, the spouse is of the opinion that I don't have time for SU or KT.) 😛
                                          I started thinking of rendering again, only after completing the "weave" geodesic ball in SU. I knew that, with all those curves and crossovers, it would make a nice subject for reflective materials, lighting and depth-of-field studies. (Participants have demonstrated that to be the case.)
                                          @notareal said:
                                          "btw if you are looking thin film interference like effect for KT, you can find a procedural texture, mIridescent, in Procedural Textures by Chris Hegarty (Windows)"
                                          Thanks, notareal. I've downloaded "procedurals.zip" (and, also, "Iridescent Glass.mat.zip") from the KT forum, and will check out their iridescent render results.
                                          -Taff
                                            liam887
                                            not very good at rendering in kerk still got far too much too learn! did this anyway thought I would post it up.
                                            VISIT MY ONLINE GALLERY
                                            • 4 / 6
