    Curviloft (Beta) Plugin Tutorial
    45 Posts 21 Posters 59.5k Views 21 Watching
    • charly2008C Offline
      charly2008
      today I want to show some basic techniques with "Curviloft. So far I have not explored all the parameter changes. I used mainly the Twistung function. For the basic shape I used the tool "Perpendicular Faces". Basically, almost all Faceprofiles are possible. The selection of the faces should always happen in a consecutive way. Otherwise it is difficult to unforeseeable results.
      The possibilities are almost no limits set.
      Charly
        dedmin
          d12dozr
          Thanks Charly
          http://goo.gl/f7ooYh
          • MALAISEM Offline
            MALAISE
            THanks Fredo and Charly for this amazing explanations. 👍 👍 👍
            Now, some special shapes can be made ( columns in Church..)
              Very cool tut 👍
              In this particular case
              Seems that follow me and rotate by Wikii is more easy : no click to make 😉
              (you can add a coef of size dimension)
              But of course less versatile than curviloft 😄
              ( one click image if scrollbar 😉
                charly2008
                Hi Pilou,
                yes, FAR is simple if only one surface profile has to be generated over the entire route. The advantage of curviloft is that one can influence the shape by different surface profiles and dimensions.
                  charly2008
                  Basic steps for a ring.
                    charly2008
                    another ring rendering with indigo
                      That is a true gem of jeweller! 👍
                      And another very clear tut! ☀
                      It's always amazing that a simple face propagated to a curve(s) gives fantastic result!
                        Using Grow by Tig for have graduate rotation size of curves,
                        Curviloft for join them by Fredo6
                        then FredoScale for bend them
                        then mirror & Rotatation/Copy
                        Click for enlarge
                          charly2008
                          Only an Idea.
                          • troyhomeT Offline
                            troyhome
                            charly2008,
                            How do you get your various shapes to be orientred perpendicular to your serpentine paths?
                            IOviz.com
                            SU Pro 2024 PC
                              charly2008
                              Hi Troy,
                              i used perpendicular faces along a perpendicular edge and scaled each individual face.
                              Charly
                              Mensch.skp
                              • troyhomeT Offline
                                troyhome
                                Nice. Thank. this is a great plug in for doing gothic details!
                                IOviz.com
                                SU Pro 2024 PC
                                • Chris FullmerC Offline
                                  To clarify, Perpendicular faces is a plugin. Check it out here:
                                  http://forums.sketchucation.com/viewtopic.php?f=323&t=17396
                                  It is useful for things like this.
                                    charly2008
                                    Hi Curviloft Friends,
                                    here some different ideas.
                                    Charly
                                      guy
                                      Amazing stuff. I have a laughable question. Can you please tell me where I find the sub division options you have used at the start of your tutorial? I can`t seem to find it!
                                      Guy
                                        charly2008
                                        Hi Guy,
                                        the subdivision is done automatically By Curviloft. The bending of the objects is done by orthogonal junction by Bezier curves. See Image below.
                                        Charly
                                          charly2008
                                          With simple geometric shapes can be created the most amazing ornaments. If, for example, useful for stucco.
                                          Charly
                                          Curviloft99.skp
                                            charly2008
                                            Robert111 was asking for a Tutorial for this crown Object shown in the image below. The original model i deleted some weeks ago.
                                            Draw some curves. Place some faces with the perpendicular faces plugin. scale each face as you want.
                                            Connect all Faces with Curviloft and make it group. Copy and flip the copy and put it together and group it again and copy the new goup. The new group may now scaled if you want more thickness for example.
                                            Rotate or flip the group to the z-direction and place it at a circle. Than make Rotate copy, that's all.
                                            I have also made the edge with perpendicular faces and Curviloft.
                                            Charly
                                            • 1 / 3
