    One controller
    21 Posts 3 Posters 3.2k Views 3 Watching
    • H Offline
      hpnisse
      Somewhere in the model, just create a static box or something and put this (and the steering script) in the "ontick" field!
      Then it will work πŸ˜„
      ** %(#BF0000)[/hpnisse]**
      %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
      • V Offline
        Vtec234
        wow thx my friend xD
        • H Offline
          hobbnob
          same thing as hpinsse's script, just all in one place:
          setVar("drive",-(0.5-righty))
          both do exactly the same thing, just that's shorter.
          My WIP Thread:Here
          • V Offline
            Vtec234
            umm yea now i made a car (without steering, just forward and backward), but it doesn't move backward, only forward O.o A standard question: what is going on? xD
            • H Offline
              hobbnob
              what scripts did you use?
              My WIP Thread:Here
              • V Offline
                Vtec234
                well i used the hpnisse's script, now im trying yours
                • V Offline
                  Vtec234
                  both don't work backward πŸ˜•
                  • H Offline
                    hpnisse
                    I've got both work correct both forward and backwards.
                    Download and look this model.
                    hpnisse vs hobbnob.skp
                    I don't know what you did but here I got both working with the up/down arrowkeys at same time.
                    Hope this helps understanding! πŸ˜„
                    /hpnisse
                    • V Offline
                      Vtec234
                      i checked it... and yea it works, but in my model, i think that its something with wheels... check this:
                      Car
                      • H Offline
                        hpnisse
                        You use servo as motor, I changed it so all servo is the "motor" joint insted. and it work perfect. πŸ˜‰
                        Then I use my script and changed some stuffs so it would be easy to change the speed.
                        SamochΓ³d.skp
                        To change the speed of the wheels then change the number "3" in the "Speed" box.
                        if frame==1
                        setVar("speed",3)
                        then it will work fine.
                        /hpnisse
                        • V Offline
                          Vtec234
                          ow... thanks i didn't think about the motor joint πŸ˜„
                          thank you guys for all the help - this forum users are really intelligent - the car works perfecto πŸ˜‰
                          • H Offline
                            hpnisse
                            Good that your happy. πŸ˜„
                            Have a nice summer!
                            • V Offline
                              Vtec234
                              Thanks and you too ;D Ow, but an other question - what scripting language is it written in?
                              @EDIT
                              Because some of those Sketchy things are in Ruby.. but i think SketchyPhysics doesn't use it...
                              • H Offline
                                hpnisse
                                It should be in ruby I think.
                                http://sketchyphysics.wikia.com/wiki/Ruby
                                It says that Ruby is used to control SketchupPhysics so I think SP would be written in that script.
                                • V Offline
                                  Vtec234
                                  sooo.. now im gonna learn it a bit ;D
                                  P.S.
                                  The topic can be closed now
