    One controller
    21 Posts 3 Posters 3.3k Views 3 Watching
    • V
      Vtec234
      well i used the hpnisse's script, now im trying yours
      • V
        Vtec234
        both don't work backward πŸ˜•
        • H
          hpnisse
          I've got both work correct both forward and backwards.
          Download and look this model.
          hpnisse vs hobbnob.skp
          I don't know what you did but here I got both working with the up/down arrowkeys at same time.
          Hope this helps understanding! πŸ˜„
          /hpnisse
          ** %(#BF0000)[/hpnisse]**
          %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
          • V
            Vtec234
            i checked it... and yea it works, but in my model, i think that its something with wheels... check this:
            Car
            • H
              hpnisse
              You use servo as motor, I changed it so all servo is the "motor" joint insted. and it work perfect. πŸ˜‰
              Then I use my script and changed some stuffs so it would be easy to change the speed.
              SamochΓ³d.skp
              To change the speed of the wheels then change the number "3" in the "Speed" box.
              if frame==1
              setVar("speed",3)
              then it will work fine.
              /hpnisse
              • V
                Vtec234
                ow... thanks i didn't think about the motor joint πŸ˜„
                thank you guys for all the help - this forum users are really intelligent - the car works perfecto πŸ˜‰
                • H
                  hpnisse
                  Good that your happy. πŸ˜„
                  Have a nice summer!
                  • V
                    Vtec234
                    Thanks and you too ;D Ow, but an other question - what scripting language is it written in?
                    @EDIT
                    Because some of those Sketchy things are in Ruby.. but i think SketchyPhysics doesn't use it...
                    • H
                      hpnisse
                      It should be in ruby I think.
                      http://sketchyphysics.wikia.com/wiki/Ruby
                      It says that Ruby is used to control SketchupPhysics so I think SP would be written in that script.
                      • V
                        Vtec234
                        sooo.. now im gonna learn it a bit ;D
                        P.S.
                        The topic can be closed now
                        • 2 / 2
