    If Toolbar is true make it false
    54 Posts 4 Posters 4.9k Views 4 Watching
      simonstaton
      hmm that method didnt work either it must be somthing to do with my .rb code. any chance either of you could quick put the following in a .rb file in your plugins and see if closes the toolbar when sketchup loads:
      status = if UI.toolbar_visible?('GettingStarted')
      Sketchup.send_action(21992)
      if it does then it must be somthing to do with my sketchup
      Thanks,
      Simon
        simonstaton
        ok through the ruby code I recieve the following method after ive just installed sketchup 7 and tryed it in there:
        (eval):894: syntax error
        status = if UI.toolbar_visible?('GettingStarted') Sketchup.send_action(21992) end
        (eval):894
        Error: #<SyntaxError: (eval):894: compile error
        (eval):894
        • Dan RathbunD Offline
          Dan Rathbun
          Simon use the code ... /code blocks, so it looks like this:
          The Code button on the post edit toolbar will insert them for you.
          I'm not here much anymore.
            simonstaton
            ok will do thanks dan, sorry just new to forums, well not new joined 2 years ago but not used to it.
              Dan Rathbun
              need to be 3 lines, not all on 1 line, or else you must finish statements with a semi-colon ( ; ).
                Dan Rathbun
                in the console (ver 7 😞
                if UI.toolbar_visible?('GettingStarted'); Sketchup.send_action(21992); end
                with the toolbar off, does nothing and returns nil.
                with the toolbar visible, it hides the toolbar and returns true.
                  simonstaton
                  great that worked in sketchup 7, however when I put it inside of my .rb file it dosnt work. to test it out could I simply just add a new .rb file inside of the plugins folder and inside there put:
                    simonstaton
                    ok I have got:
                    working in my v6 through the ruby console however how come when I put it inside of my .rb file it does not work?
                    could there be errors?
                      Dan Rathbun
                      > end
                      Yes I put things like this in a rb called "!Defaults.rb"
                      The exclamation makes it load before alpha characters because of the position of ! in the ASCII set.
                      Also you don't need "status =" if you will not use the status reference.
                        Dan Rathbun
                        of course there could be!
                        πŸ˜†
                          simonstaton
                          I see so how would I load up a new .rb file to have this in, is it as simple as making a file called hidetool.rb then inside there putting
                          !Defaults.rb
                            Dan Rathbun
                            @simonstaton said:
                            ..., is it as simple as making a file called hidetool.rb then inside there putting
                            No.. name the FILE --> !Defaults.rb
                            # defaults for Sketchup Startup
                            begin
                              # hide the GettingStarted toolbar
                              Sketchup.send_action(21992) if UI.toolbar_visible?('GettingStarted')
                            P.S. the send action line is all 1 line in the above example.
                              simonstaton
                              > begin
                              > end
                              legend that seems to be working however each time I load sketchup it seems to toggle it on and off, so the first time I load it it turns it off then I close and reopen then its turned on.
                                Dan Rathbun
                                Close sketchup.
                                Rename Plugins folder -> xPlugins
                                make a new Plugins folder
                                copy the !Defaults.rb file into the new folder
                                Restart Sketchup
                                if it works, some other file is causing problems
                                if it doesn't work, then it's a ver 6 bug
                                (when done restore your folders to before.)
                                Your only alternate then would be a Windows System call using Win32API.so
                                That requires a knowledge of C language and the MS Windows API.
                                  simonstaton
                                  Ok, neither of the methods worked I also tried it using v7 and its still not working.
                                  it is defiantly doing something as when all the plugins are disabled it will disable the toolbar then on the next reopen the toolbar will open so it just seems to be toggling it :s
                                    Why are you trying to turn on/off the user's toolbar in the first place?
                                      simonstaton
                                      it is so that the user can see only my toolbar which is explained when they download, what is so bloody confusing is that when I put the event:
                                      UI.set_toolbar_visible("GettingStarted", false)
                                      inside of a toolbars tool event it works fine and hides it however when I put it lose inside the .rb file nothing happens!
                                      this is driving me crazy I might just leave it as they have to click a button on my toolbar to hide it.
                                      Simon
                                        Maybe the toolbars aren't accessible when the .rb loads... ?
                                        Timed delay?
                                          simonstaton
                                          I think you are right! if its working from the ruby console and its working on the toolbar and its not working on load it must be because the toolbar is false until it has loaded.
                                          anyway to add a delay onto the .rb file and have it only run once sketchup is fully loaded?
                                            UI.start_timer
                                            http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#start_timer
                                            Note that you can only use whole seconds with the timer.
                                            • 2 / 3
