    Design House 2
    13 Posts 8 Posters 1.5k Views 8 Watching
      john.warburton
      Looking good for a brick and glass render πŸ˜‰
      You have fallen foul of the problem with jointed materials not matching the surface dimension and not wrapping correctly at corners. You are not alone in this. I have seen Holiwood movies that have this problem too.
      You need to make sure that the walls are an exact multiple of the brick dimensions (adjusted for the joint width.)
      Life's a reach, and then you gybe.
        Rico91
        thnx for reply!
        i know the problem. it's very hard to precisely make the brick on the right place on the corner.
        Mabey a little more practice on it..
        ps: i hope you understand my english 😳
        [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
          rev3rse
          The bricks have standard size, typically 5.5x12x25, so in the end it's better to correct the elevation of the walls instead of distort and adjust the textures, especially in the case of brick or similar...
            sepo
            Brick dimension is different in almost every country.
            • V Offline
              velvia
              i like your design...
              good job.. πŸ˜‰
              My show room :smile:
              http://www.velviapersky.com/category/web-design/3d-design/
                keithglass
                nice house. I would like to see more views, especially from grade level. As a practicing architectural professional, I can see that this house would have the same problem that many buildings by Frank Gehry and Frank Lloyd Wright have . . . It will leak water!!! - but nice design!
                  Rico91
                  yes i know what you mean. this is specificly about the design of the house.
                  i work on it, but i have no much time for this project.
                  but if this work is finished, i show you the nicer renders of it, with the environment etc.
                    Rico91
                    new renders are finished! πŸ˜›
                    i hope you like it!
                    and solo thnx for your beautiful 3D garden pack ! πŸ˜„
                    http://lh3.ggpht.com/_rMc47FEl0fA/TB97agUtEQI/AAAAAAAACBk/5LM1VG7XstQ/Render_1_18-06-2010.jpg
                    http://lh6.ggpht.com/_rMc47FEl0fA/TB97bSaJPTI/AAAAAAAACBo/a1et0168Tbc/Render_2_18-06-2010.jpg
                    http://lh5.ggpht.com/_rMc47FEl0fA/TB97c8buw2I/AAAAAAAACBw/IdvlVW4C4Fc/Render_4_18-06-2010.jpg
                    http://lh4.ggpht.com/_rMc47FEl0fA/TB97dU_DEVI/AAAAAAAACB0/bNSida6ZrRM/Render_5_18-06-2010.jpg
                    • shuraS Offline
                      shura
                      well done Rico, I like the design! there are some textures that look strange though, and maybe the agaves are lined up a bit too accurately - otherwise good job πŸ‘
                      • Bryan KB Offline
                        Nice!
