    Design House 2
    13 Posts 8 Posters 1.5k Views 8 Watching
      Rico91
      Hi all,
      This is my best design for so far.
      It's called 'Design house 2'.
      My plan was to make a combination of stone and glass.
      so comments are free!
      http://www.r3design.nl/images/designs/Design house 2/design house 2_model_render_11..jpg
      http://www.r3design.nl/images/designs/Design house 2/design house 2_model_render_12..jpg
      http://www.r3design.nl/images/designs/Design house 2/design house 2_model_render_13..jpg
      http://www.r3design.nl/images/designs/Design house 2/design house 2_model_render_14..jpg
      On this moment i work on the interior. if that is finished. i will start with the environment.
      [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
        sepo
        "My plan was to make a combination of stone and glass"
        I see a lot of brick but no stone at all. πŸ˜‰ BTW which renderer did you use.
          Rico91
          lol, sorry my english is very bad πŸ˜›
          i render this with Artlantis v2
            john.warburton
            Looking good for a brick and glass render πŸ˜‰
            You have fallen foul of the problem with jointed materials not matching the surface dimension and not wrapping correctly at corners. You are not alone in this. I have seen Holiwood movies that have this problem too.
            You need to make sure that the walls are an exact multiple of the brick dimensions (adjusted for the joint width.)
            Life's a reach, and then you gybe.
              Rico91
              thnx for reply!
              i know the problem. it's very hard to precisely make the brick on the right place on the corner.
              Mabey a little more practice on it..
              ps: i hope you understand my english 😳
                rev3rse
                The bricks have standard size, typically 5.5x12x25, so in the end it's better to correct the elevation of the walls instead of distort and adjust the textures, especially in the case of brick or similar...
                  sepo
                  Brick dimension is different in almost every country.
                  • V Offline
                    velvia
                    i like your design...
                    good job.. πŸ˜‰
                    My show room :smile:
                    http://www.velviapersky.com/category/web-design/3d-design/
                      keithglass
                      nice house. I would like to see more views, especially from grade level. As a practicing architectural professional, I can see that this house would have the same problem that many buildings by Frank Gehry and Frank Lloyd Wright have . . . It will leak water!!! - but nice design!
                        Rico91
                        yes i know what you mean. this is specificly about the design of the house.
                        i work on it, but i have no much time for this project.
                        but if this work is finished, i show you the nicer renders of it, with the environment etc.
                          Rico91
                          new renders are finished! πŸ˜›
                          i hope you like it!
                          and solo thnx for your beautiful 3D garden pack ! πŸ˜„
                          http://lh3.ggpht.com/_rMc47FEl0fA/TB97agUtEQI/AAAAAAAACBk/5LM1VG7XstQ/Render_1_18-06-2010.jpg
                          http://lh6.ggpht.com/_rMc47FEl0fA/TB97bSaJPTI/AAAAAAAACBo/a1et0168Tbc/Render_2_18-06-2010.jpg
                          http://lh5.ggpht.com/_rMc47FEl0fA/TB97c8buw2I/AAAAAAAACBw/IdvlVW4C4Fc/Render_4_18-06-2010.jpg
                          http://lh4.ggpht.com/_rMc47FEl0fA/TB97dU_DEVI/AAAAAAAACB0/bNSida6ZrRM/Render_5_18-06-2010.jpg
                          • shuraS Offline
                            shura
                            well done Rico, I like the design! there are some textures that look strange though, and maybe the agaves are lined up a bit too accurately - otherwise good job πŸ‘
                            • Bryan KB Offline
                              Nice!
