    String.unpack - signed 4byte little-endian integer?
    17 Posts 3 Posters 3.2k Views 3 Watching
      Thanks for that Dan. πŸ‘ πŸ‘ That confirmed my suspicion.
      Can't one rearrange the bits using ruby? If one use the RUBY_PLATFORM constant to determine if the host is a PPC, when swap the bits with ruby avoiding the need to C dependencies?
      • Dan RathbunD Offline
        Dan Rathbun
        Sure .. remember that Color Integer Conversion code I did awhile back.
        That was just swapping bits around.
        I'm not here much anymore.
          I need to revisit that. Make some le2be and be2le methods.
            MartinRinehart
            Mucking with bits in Ruby is very easy (though performance?). In VisMap I fiddled with bits in JavaScript to encode the string sent to Ruby and in reverse in the Ruby to unencode. Wrote about that in http://www.MartinRinehart.com/models/tutorial/tutorial_bfr.htmlAppendix BFR[/url].
            I apologize for the code. It dates back to when I was first writing Ruby, trying to do things the Ruby way.
              Dan Rathbun
              @dan rathbun said:
              @thomthom said:
              Can one from ruby find out what the native endian is?
              ... this page:
              http://developer.apple.com/mac/library/documentation/DeveloperTools/gcc-4.0.1/gcc/ARM-Options.html
              seems to suggest that the processor itself can run in "an endian mode".
              More info...
              (http://en.wikipedia.org/wiki/Endian#Bi-endian_hardware)":2fp65ya5]Some architectures (including ARM, PowerPC, Alpha, SPARC V9, MIPS, PA-RISC and IA-64) feature switchable endianness. This feature can improve performance or simplify the logic of networking devices and software. The word bi-endian, said of hardware, denotes the capability to compute or pass data in either of two different endian formats.
              Note, too, that some nominally bi-endian CPUs may actually employ internal "magic" (as opposed to really switching to a different endianness) in one of their operating modes. For instance, some PowerPC processors in little-endian mode act as little-endian from the point of view of the executing programs but they do not actually store data in memory in little-endian format (multi-byte values are swapped during memory load/store operations).
                Dan Rathbun
                Hmmm... looking at Array.pack it says "network byte order" is big-endian.
                Would something like this work? (you'd need to apply your platform test beforehand)
                # singleton method for String
                def myStr.swapEndian_to_i( long=true, signed=true )
                  arr=[]
                  self.each_byte {|byte| arr.unshift(byte) }
                  str=arr.join
                  if signed
                    return ( long ? str.unpack('l') ; str.unpack('s') )
                  else # unsigned
                    return ( long ? str.unpack('L') ; str.unpack('S') )
                Further Reading:
                Understanding Big and Little Endian Byte Order
                Blog: How to convert an integer to little endian or big endian
                Apple Dev: Byte Swapping Integers
                Endian FAQ
                  Good stuff Dan πŸ‘ - thanks for looking into this. I'll look into this as soon as I can. (Just need to get Vertex Tools out the window)
                    Dan Rathbun
                    from the source:
                    • ... use WORDS_BIGENDIAN to detect the platform's endian.
                    WORDS_BIGENDIAN is set in defines.h (line 163,) IF the compiler had defined BIG_ENDIAN (otherwise LITTLE_ENDIAN would have been defined.)
                    Have a look at pack.c begining line 182:
                    There is a C function declared called endian() that returns 0|1
                    .. you'll see how in that block between 182 and 280 how #ifdef DYNAMIC_ENDIAN and #ifdef WORDS_BIGENDIAN are used with the endian() function to control how values are converted.
                    The endian() function only gets declared if DYNAMIC_ENDIAN is defined.
                    But you could do something similar in πŸ˜„
                    #include 'ruby.h'
                    #include 'defines.h'
                      /* define a ruby constant that returns true */
                    #else
                      /* define a ruby constant that returns false */
                    #endif
                      Dan Rathbun
                      Another idea, since on the Mac you have a full Ruby install..
                      is to see what the compiler -archflags were when Ruby was built for the PPC.
                      The Config::CONFIG hash contains alot of info:
                      At console try:
                      Config::CONFIG['ARCH_FLAG']
                      or just open the rbconfig.rb file in the arch_sub_folder (ppc-darwinX.X) of the ruby lib folder and manually browse the whole hash for possible info.
                        Dan Rathbun
                        TT,
                        Just posted a Platform module in the SKX forum that has some Pure Ruby Endianess hacks.
                        http://forums.sketchucation.com/viewtopic.php?f=315&t=29132#p253630
                          That sounds good. πŸ‘
                          I still haven't been able to look at this. Trying to crunch out Vertex Tools.
