Scambler and wildcards?
Is there a way to provide wildcards to the scrambler?
I've tried this: (setting up a .BAT files)
scrambler.exe Build\*.rbCan one specify the output folder for the scrambler?
Or would I need to make the batch file iterate the folder and pass the filename for each to the scrambler and move the .rbs to where I want them?
@thomthom said:
- Is there a way to provide wildcards to the scrambler?
NO.
Trying to pass a wildcard pathname results in the following error message:
*Scrambler failed to create .rbs
@thomthom said:
- Can one specify the output folder for the scrambler?
NO. It just outputs to the current working directory.
As I suspected then. Well, a batch file does the trick.
