    Scambler and wildcards?
    4 Posts 2 Posters 316 Views 2 Watching
      Is there a way to provide wildcards to the scrambler?
      I've tried this: (setting up a .BAT files)
      scrambler.exe Build\*.rb
      Can one specify the output folder for the scrambler?
      Or would I need to make the batch file iterate the folder and pass the filename for each to the scrambler and move the .rbs to where I want them?
      • Dan RathbunD Offline
        Dan Rathbun
        @thomthom said:
        1. Is there a way to provide wildcards to the scrambler?
        NO.
        Trying to pass a wildcard pathname results in the following error message:
        *Scrambler failed to create .rbs
        I'm not here much anymore.
          Dan Rathbun
          @thomthom said:
          1. Can one specify the output folder for the scrambler?
          NO. It just outputs to the current working directory.
            As I suspected then. Well, a batch file does the trick.
