    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    Sketchup.send_action arguments: Mac vs PC
    10 Posts 5 Posters 3.3k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      (http://groups.google.com/group/sketchupruby/tree/browse_frm/thread/92997374d3b27253/c20239069310f1fa?rnum)":1jz3lpx6] But it brings up this question -
      "showRubyPanel:" vs. CMD_RUBY_CONSOLE
      Dan or anyone - is there a preference?
      The preference will always be that which IS cross-platform, and will likely be so in the future.
      CMD_RUBY_CONSOLE is nothing more than a constant, that on the PC, points to the Integer object 21478.
      But these integer arguments only work on the PC.
      I have asked these question before, and did not get an answer:
      [Actually my question was in regard to ALL of the constants.]
      (1) Are the constants cross-platform (ie: does CMD_RUBY_CONSOLE constant exist on the Mac?)
      (2) If so, what value is the constant CMD_RUBY_CONSOLE pointing at on the Mac ?
      It seems that the string argument "showRubyPanel:" (and all of the other string arguments for Sketchup.send_action,) ARE cross-platform.
      So we might stick with those, until someone answers the question of Mac constants.
      _
      I'm not here much anymore.
        A la Jim
        (Object.constants.grep /CMD/).sort
        ["CMD_ARC", "CMD_CAMERA_UNDO", "CMD_CIRCLE", "CMD_COPY", "CMD_CUT", "CMD_DELETE", "CMD_DIMENSION", "CMD_DISPLAY_FOV", "CMD_DOLLY", "CMD_DRAWCUTS", "CMD_DRAWOUTLINES", "CMD_ERASE", "CMD_EXTRUDE", "CMD_FREEHAND", "CMD_HIDDENLINE", "CMD_LINE", "CMD_MAKE_COMPONENT", "CMD_MEASURE", "CMD_MOVE", "CMD_Mover", "CMD_NEW", "CMD_OFFSET", "CMD_OPEN", "CMD_ORBIT", "CMD_PAGE_DELETE", "CMD_PAGE_NEW", "CMD_PAGE_NEXT", "CMD_PAGE_PREVIOUS", "CMD_PAGE_UPDATE", "CMD_PAINT", "CMD_PAN", "CMD_PASTE", "CMD_POLYGON", "CMD_POSITION_CAMERA", "CMD_PRINT", "CMD_PROTRACTOR", "CMD_PUSHPULL", "CMD_RECTANGLE", "CMD_REDO", "CMD_ROTATE", "CMD_RUBY_CONSOLE", "CMD_SAVE", "CMD_SCALE", "CMD_SECTION", "CMD_SELECT", "CMD_SELECTION_ZOOM_EXT", "CMD_SHADED", "CMD_SHOWGUIDES", "CMD_SHOWHIDDEN", "CMD_SKETCHAXES", "CMD_SKETCHCS", "CMD_TEXT", "CMD_TEXTURED", "CMD_TRANSPARENT", "CMD_UNDO", "CMD_VIEW_BACK", "CMD_VIEW_BOTTOM", "CMD_VIEW_FRONT", "CMD_VIEW_ISO", "CMD_VIEW_LEFT", "CMD_VIEW_PERSPECTIVE", "CMD_VIEW_RIGHT", "CMD_VIEW_TOP", "CMD_WALK", "CMD_WIREFRAME", "CMD_ZOOM", "CMD_ZOOM_EXTENTS", "CMD_ZOOM_WINDOW"]
        and these are effectively the same as the send_action's ๐Ÿ˜’
          Dan Rathbun
          Guys.. I can do that on Windows as well. Both you guys have WIN systems?
          (a) I know the constants DO exist on Windows SU.
          (b) I know the constants point to Integer object(s) on Windows.
          The questions relate to the Mac.
          Let me restate the questions:
          (1) Are the constants cross-platform (ie: do they exist on the Mac?)
          (2) If so, what value (or types,) do the constant(s) point at on the Mac ?
            Jim
            Sorry Dan, that screenshot was from my Mac. I haven't had a chance to actually see if they work.
              Dan Rathbun
              Firstly Thanks!
              OK, so answer to question (1) is:
              They DO exist on the SU Mac edition.
              We need to know if they do.
              I find it strange that (on the Mac,) CMD_RUBY_CONSOLE returns the Integer 21478. These integer arguments (according to the API,) are only supposed to work on the PC edition.
              How about a little test scriplet:
              module SUAPI
                def self.list_commands
                  cmds = (Object.constants.grep /CMD/).sort
                  plat = ( RUBY_PLATFORM =~ /(mswin|mingw)/i ? 'Windows' ; 'Mac' )
                  txt = "\n Sketchup Command Constants for #{plat} Platform\n"
                  txt << "-------------------------------------------------\n"
                  cmds.each {|e|
                    val = eval(e)
                    txt << " %-22s = " % e << "#{val.to_s}  (#{val.class.to_s})\n"
                  txt << "\n\n"
                  return txt
                end #method
              end #module
              The block of text returned can be sent to a file, or to a webdialog, or even a multiline messagebox:
              UI.messagebox( SUAPI.list_commands, MB_MULTILINE, 'Command Constants' )
              although it doesn't look so good when not in a fixed-width font.
                Dan Rathbun
                New Question: Cut, Copy and Paste
                We have standard Windows integer commands for these:
                %(#BF0000)[CMD_CUT
                CMD_COPY
                CMD_PASTE]
                What are the Mac equivalents ??
                ... do these work as Sketchup.send_action() arguments?
                %(#BF0000)["cut:"
                "copy:"
                "paste:"]
                  driven
                  this what you need?
                  Sketchup Command Constants for Mac Platform
                  %(#004080)[CMD_ARC = 21065 (Fixnum)
                  CMD_CAMERA_UNDO = 10529 (Fixnum)
                  CMD_CIRCLE = 21096 (Fixnum)
                  CMD_COPY = 57634 (Fixnum)
                  CMD_CUT = 57635 (Fixnum)
                  CMD_DELETE = 21021 (Fixnum)
                  CMD_DIMENSION = 21410 (Fixnum)
                  CMD_DISPLAY_FOV = 21494 (Fixnum)
                  CMD_DOLLY = 10523 (Fixnum)
                  CMD_DRAWCUTS = 21348 (Fixnum)
                  CMD_DRAWOUTLINES = 21347 (Fixnum)
                  CMD_ERASE = 21019 (Fixnum)
                  CMD_EXTRUDE = 21525 (Fixnum)
                  CMD_FREEHAND = 21031 (Fixnum)
                  CMD_HIDDENLINE = 10511 (Fixnum)
                  CMD_LINE = 21020 (Fixnum)
                  CMD_MAKE_COMPONENT = 21083 (Fixnum)
                  CMD_MEASURE = 21024 (Fixnum)
                  CMD_MOVE = 21048 (Fixnum)
                  CMD_NEW = 57600 (Fixnum)
                  CMD_OFFSET = 21100 (Fixnum)
                  CMD_OPEN = 57601 (Fixnum)
                  CMD_ORBIT = 10508 (Fixnum)
                  CMD_PAGE_DELETE = 21078 (Fixnum)
                  CMD_PAGE_NEW = 21067 (Fixnum)
                  CMD_PAGE_NEXT = 10535 (Fixnum)
                  CMD_PAGE_PREVIOUS = 10536 (Fixnum)
                  CMD_PAGE_UPDATE = 21068 (Fixnum)
                  CMD_PAINT = 21074 (Fixnum)
                  CMD_PAN = 10525 (Fixnum)
                  CMD_PASTE = 57637 (Fixnum)
                  CMD_POLYGON = 21095 (Fixnum)
                  CMD_POSITION_CAMERA = 21169 (Fixnum)
                  CMD_PRINT = 57607 (Fixnum)
                  CMD_PROTRACTOR = 21057 (Fixnum)
                  CMD_PUSHPULL = 21041 (Fixnum)
                  CMD_RECTANGLE = 21094 (Fixnum)
                  CMD_REDO = 57644 (Fixnum)
                  CMD_ROTATE = 21129 (Fixnum)
                  CMD_RUBY_CONSOLE = 21478 (Fixnum)
                  CMD_SAVE = 57603 (Fixnum)
                  CMD_SCALE = 21236 (Fixnum)
                  CMD_SECTION = 21337 (Fixnum)
                  CMD_SELECT = 21022 (Fixnum)
                  CMD_SELECTION_ZOOM_EXT = 21469 (Fixnum)
                  CMD_SHADED = 10512 (Fixnum)
                  CMD_SHOWGUIDES = 21980 (Fixnum)
                  CMD_SHOWHIDDEN = 21154 (Fixnum)
                  CMD_SKETCHAXES = 10522 (Fixnum)
                  CMD_SKETCHCS = 21126 (Fixnum)
                  CMD_TEXT = 21405 (Fixnum)
                  CMD_TEXTURED = 10539 (Fixnum)
                  CMD_TRANSPARENT = 10513 (Fixnum)
                  CMD_UNDO = 57643 (Fixnum)
                  CMD_VIEW_BACK = 10505 (Fixnum)
                  CMD_VIEW_BOTTOM = 10506 (Fixnum)
                  CMD_VIEW_FRONT = 10502 (Fixnum)
                  CMD_VIEW_ISO = 10507 (Fixnum)
                  CMD_VIEW_LEFT = 10504 (Fixnum)
                  CMD_VIEW_PERSPECTIVE = 10519 (Fixnum)
                  CMD_VIEW_RIGHT = 10503 (Fixnum)
                  CMD_VIEW_TOP = 10501 (Fixnum)
                  CMD_WALK = 10520 (Fixnum)
                  CMD_WIREFRAME = 10510 (Fixnum)
                  CMD_ZOOM = 10509 (Fixnum)
                  CMD_ZOOM_EXTENTS = 10527 (Fixnum)
                  CMD_ZOOM_WINDOW = 10526 (Fixnum)]
                  john OSX 10.5.8
                    Dan Rathbun
                    %(#BF0000)["cut:"
                    "copy:"
                    "paste:"]
                    I verified that the above strings work on Windows PC. (SU ๐Ÿ˜Ž
                    And John verified that they work on the Mac.
                    So:
                    Sketchup.send_action("paste:") is cross-platform,
                    And:
                    Sketchup.send_action( CMD_PASTE ) is not.
                    Unless Mac users reassign the constants, like:
                    CMD_PASTE = "paste:"
                      Jim
                      SketchUp 7.1.6859
                      Mac OS X 10.4.11
                        brandenberg
                        This is an old thread, but I'm adding a tip here that may be of help to other developers who may discover this info...
                        In an effort to create a toolbar button to show the "Entity Info" palette (there's a built-in button for Model Info, but oddly not for Entity Info), I couldn't find a method or action that worked on the Mac. There is a fixnum constant value for the PC, but these don't seem to work on the Mac, even after years of SketchUp evolution on the Mac. Then I stumbled on the get_shortcuts method...
                        Using the "Shortcuts" pane within the "Preferences" window, you can add a shortcut to the command for which you need the string constant, then using:
                        Sketchup.get_shortcuts.sort
                        ...you can discover the string that can successfully be used with the Sketchup.send_action method. For example, I added the F2 key to "Window/Entity Info", and got the following output:
                        ["A\tselectSelectionTool:", "B\tselectPaintTool:", "C\tselectCircleTool:", "E\tselectEraseTool:", "F\tviewZoomExtents:", "F2\tentityProperties:", "G\tmakeGroup:", "H\tselectDollyTool:", "K\ttoggleDisplayBackEdges:", "L\tselectLineTool:", "O\tselectOrbitTool:", "P\tselectPushPullTool:", "R\tselectRotateTool:", "S\tselectScaleTool:", "T\tselectMeasureTool:", "V\tselectMoveTool:", "Z\tselectZoomTool:", "`\ttoggleHideRestOfModel:", "~\ttoggleHideSimilarComponents:", "โ‡งG\t/Edit/Context Menu Flyout/Explode"]
                        In there, you'll see "F2\tentityProperties:", so the string constant is "entityProperties:".
                        Voila, a method to discover undocumented action strings.
