    HDRI's
    26 Posts 9 Posters 2.5k Views 9 Watching
    • urgenU
      urgen
      @flipya said:
      @dale said:
      but isn't it a Photoshop Plugin?
      The 'Pro Plus Bundle' comes with a plugin indeed.
      Oddly enough they state 'Photoshop CS2/CS3/CS4/CS5' but when you click on requirements it says 'i.e. versions other than Photoshop CS2 or higher will not work with HDR images.' πŸ˜•
      Link...
      ....If you wish to create HDRI images and HDRI maps, you should use PhotoshopCS3/CS4/CS5 EXTENDED
      --pupil forever...------
      • honoluludesktopH
        honoluludesktop
        I googled HDIR and the explanations I found have to do with adjusting an image's dynamic range. Some examples had to do something with using different photos of the same view to produce a usable image. Can someone explain what HDIR means in this discussion? Thanks.
          Roger
          Large PANO of Sedona Arizona
          Sedona, AZ
          Detail from the original of the above image. Can you see where this came from?
          Detail
          Here is a much reduced panorama. It was shot handheld in about 15 frames and stitched with MicroSoft Image Composite Editor (MSICE)which is a free download from Microsoft. When you shoot you want to overlap each frame by about 30 percent. If you are doing HDRI with bracketed exposure, it would be better to shoot from a tripod with a precise rotator head to mike sure the frames are properly aligned.
          With narrow strips like this, nodal point alignment is not a big deal. Nodal points are a bigger issue as you begin shooting above and below the horizon. The nodal point (some people say this terminology is inaccurate but I will use it now for convenience)is where the light rays seem to cross as light is inverted by the lens. The actual point can be in front of the lens in the lens or behind the lens. For an accurate image all movement of the camera between shots has to pivot around this point. The tripod screw under your camera is may not line up with the nodal point and the up and down rotation of the tripod head certainly does not. This is the reason pano heads are sold that go from $85 to $500 and $600. Without a perfectly aligned nodal point, the dog hiding behind the fireplug in one frame may reappear next to the fireplug in the next frame. This becomes a real issue in close foregrounds. Some software will try to compensate, but it will cause a quality tradeoff.
          The most convenient system comes from gigapan.com. These guys are Carnegie Mellon University graduates that designed some of the robotic camera systems for the Mars rovers. There gadget is a robot cradle that will align your camera over your lenses nodal point, move the camera rapidly between exposures, and take into account the bracketing requirements of HDRI.
          Gigapan images can be almost unlimited in resolution, which raises what is the use of an unlimited resolution image. Previously end use has been limited by the resolution of your screen or the printed page. However, with extremely large gigapan images you can host the image on their server and let users dynamically interact with the image. On famous picture of the Obama inauguration shows the whole capital mall with 10,000 people in attendance. However a viewer can still zoom in until you can see Joe Biden's cuff links
          This is the high end. Pano heads are in the mid range bur require more work from the camera operator. You can also use low quality gimmick lenses.
          However some of the low end gimmick attachments might work just fine if you are using your HDRI images as ambient lighting references and background not requiring a great deal of sharpness.
          This turned into more than I intended to write, but if you have specific questions I would be glad to help.
          http://www.azcreative.com
          • pyrolunaP
            pyroluna
            Wow roger! You are clearly a pro! That is one awesome pano!
            Uh... So Im guessing the detail is from the left of the original, right between that big tree and that little one?
              d12dozr
              Yeah great info Roger!
              Is the detail from the left (maybe 25% in) just under the shadow of the mountain?
              http://goo.gl/f7ooYh
              • Mike LuceyM
                Mike Lucey
                My guess πŸ˜„
                  Roger
                  Wow FireyMoon, close, but not quite. The mountain on the left has a sunny side and a shadow side. At the bottom of the shadow side and just above the tree line are a couple of reddish pixels. The inset detail comes from the area those pixels represent.
                  I actually was working on design of a pano head and was using SketchUp as my design tool. I was going to order extrusions from the 80/20 company to build some of the components. They offered a custom design service for special components not in the catalog. I designed a special rotating part and sent the drawing to their design department for custom manufacturing, but they said they would not take SketchUp as an input when, in fact, I had made conventional plans and elevations as well as 3D views. They go to great lengths to create comprehensive catalogs and operate a custom manufacturing department, but it is all for naught when you have to talk to someone with a lot of wax in their ears.
                    Roger
                    Ah Mike et al, you got there before me. Thank you.
                    • Mike LuceyM
                      Mike Lucey
                      They don't call me old eagle eye for nothing ..... trouble is I sometimes see to much and that can get you into trouble πŸ˜’
                      • Mike LuceyM
                        Mike Lucey
                        On the subject of panos, I came across AutoStitch for the iPhone http://www.cloudburstresearch.com/autostitch/autostitch.html I tend to use the iPhone for much of the pics I take and find AutoStitch very useful. Its good value at $2.99!
                        • daleD
                          dale
                          Thanks Roger for that detailed explanation. A question... to create a hemispherical global, is it a matter of lens, or do you have to rotate the camera on the z axis as well?
                          • daleD
                            dale
                            honolulu I posted this to learn also, but I will try to answer your question, and maybe someone with more knowledge than me can jump in.
                            Dynamic range can be referred to as a ratio. In a scene it is the ratio between two luminance values, in essence the lightest and the darkest. By taking a photograph of the same scene using different exposures, and then using computer software you are able to extract greater detail from these exposures, from smallest unit a computer can store, the bit. A quote I read and kept around ...... "Therefore, an HDR image is encoded in a format that allows the largest range of values, e.g. floating-point values stored with 32 bits per color channel.
                            Another characteristics of an HDR image is that it stores linear values. This means that the value of a pixel from an HDR image is proportional to the amount of light measured by the camera. In this sense, HDR images are scene-referred, representing the original light values captured for the scene.
                            Whether an image may be considered High or Low Dynamic Range depends on several factors. Most often, the distinction is made depending on the number of bits per color channel that the digitized image can hold." here is a link to that discussion http://www.hdrsoft.com/resources/dri.html#dr
                            I am interested in them more for rendering, than strictly photography, as when I use them as a source for lighting in rendered images, the results always seem much better to me.
                            • daleD
                              dale
                              I came across a very beautiful HDRI Photo on the website of CCY Architects http://www.ccyarchitects.com/ Since the site contained no copyright notice, I will put it up here and gladly remove it if it offends them. Perhaps the phootgrapher will come forward and take credit.
                                Roger
                                The answer is, it depends.
                                You can use a 180 degree fisheye lens and lay on your back looking up and get a hemisphere in one shot. Or you take the other extreme and shoot a hundreds of shots with an extreme telephoto (in the x,y and z axes and stitch them together).
                                The difference between the two is amount of work and resolution. The fish eye will be in the 5 to 10 megabyte range. The stitched image could be 40, 100 or even more gigabytes.
                                Mesa Arts Center
                                This is MAC (The Mesa Arts Center)in Mesa, Arizona. If I remember right this is composed of a matrix of 12 photos (4 across by 3 high). I guess the FOV might be 120 degrees. I had to do a fair amount of PS to get rid of the worst distortion. For comparison SketchUps dfault FOV is 35 degrees and I estimate our sharp field of view to be about 12 degrees.
                                As humans we stitch the images in front of us all the time, but we do it in our brain and in our memory. At 12 degrees we are really looking through a keyhole, but as the eye scans a scene it gathers many views and stitches them together. In fact this is also HDRI as I took a normal and underxposed view of ever position so I could keep the sails from over exposing. We are looking at two layers of 12 shots each.
                                • 2 / 2
