    Best tool for cutting terrain.
    Scheduled Pinned Locked Moved Google Earth
    4 Posts 2 Posters 12.0k Views 2 Watching
      jwallis
      HI
      I wish to simulate the digging of a trench on some textured terrain that has been snapshot from google earth.
      I am not yet aware of which tool i should be using to cut into the terrain to create the longitudinal void needed for the trench.
      Any ideas. Sandbox tools?
        jwallis
        I should make clear that this being terrain, it is not a flat plane.
        • GaieusG
          I think JointPushPull (plugin) could do it easily. Do you need vertical walls for the trench? If not, the Smoove tool (on pre-selected areas) of the Sandbox would also be fine. Needs some experimenting with its offset values (can never be 0 to make really vertical walls).
          Or even the Stamp tool could do it (again, not with 0 offset)
            jwallis
            thanks again Gaieus.
            I have actually used that plugin before so will investigate.
