    C Extension on OSX crashes SU
    18 Posts 5 Posters 4.1k Views 5 Watching
      driven
      @thomthom said:
      require "/Users/thomas/Sketchup Plugins/Vertex Edit/CExt/TT_Hamster"
      I can't require /TT_Hampster from TT_Hampster.bundle, I need a load ruby or something,
      other plugins I have that use .bundle (that are also located in the SU plugins folder) access them through separate load rubies
      other apps that use .bundles keep the bundles in the separate system folders
      so, I guess I just don't know where to put it or how to open, but I'm willing to try following detailed instruction if it helps
        TT_Hamster.bundle instead of TT_Hampster.bundle would help...
        ...or was that just a typo in the post?
          driven
          a typo in the post, but I just spotted
          to be on the safe side shouldn't your path be
          >> require "/Library/Application\ Support/Google\ SketchUp\ 7/SketchUp/Plugins/Vertex Edit/CExt/TT_Hamster"
          I know some plugins run from other folders quite happily, but for SU it can be a problem...
          just a thought
            From the IRB it should work regardless.
            Yes, all depending on how they locate their files. My plugin uses the path to the loading .rb as base to determine the subfolders. Works fine on PC.
            I set it up in an isolated folder for development, with the development folder added to the include path.
            But it is strange that you can't even load it from IRB...
              driven
              I'm not very familiar with IRB, so it probably my error.
              maybe you could give me more specific instruction...
              when I unzip d/l file I put "TT_Hamster.bundle" into my SU plugins folder
              in SU Ruby Console I run your .rb code and get
              > require 'mkmf'
              create_makefile("TT_Hamster")
              Error; #<LoadError; (eval);507;in `require'; no such file to load -- mkmf>
              (eval);507
              (eval);507
              so, what am I doing wrong??
                I'm confused - are you using the SU Ruby Console or the IRB to test it?
                > require 'mkmf'
                Ohhh - now I see. That bit is what I used to compile the extension.
                TT_Hamster.bundle is the compiled result of that.
                You should only need to
                require "TT_Hamster" - this assumes that TT_Hamster.bundle is in the current working directory.
                  macumber
                  I checked and have a similar problem. I have only been testing my extension in SketchUp on Windows and IRB on Windows/Mac. I'm going to look into it too and will post anything I find here.
                  Dan
                  • AdamBA
                    AdamB
                    > require 'mkmf'
                    You have to link as a flat namespace otherwise it won't work on OSX.
                    LDSHARED = cc -dynamic -bundle -undefined suppress -flat_namespace
                      πŸ‘
                      I don't know at all what that line actually do, but I replaced what was generated by the extconf.rb file:
                      LDSHARED = cc -arch ppc -arch i386 -pipe -bundle -undefined dynamic_lookup
                      Using that line you posted and everything worked great!
                      I need to work out what it is this does. And how this make system works. I could not even recompile without erasing an .o file that was also generated last time I ran make. ❓ 😳
                      Thank you very much Adam! I owe you a cookie!
                        I notice the old line had something in it, -arch ppc - would that have made it compatible with PPC macs?
                        I have an old G4 Mac Mini as well as the Intel Mac. Can I compile on the Intel mac in a manner so that the extension will run on both systems?
                        • AdamBA
                          AdamB
                          You'll need to add:
                          "-arch i386 -arch ppc"
                          to CFLAGS and DLDFLAGS
                          This will make the Mac compiler build your code for both PowerPC and Intel CPUs.
                            Thanks! πŸ‘
                            How did you work out that flat namespace is needed for SU Ruby? Since it isn't needed for when you use the normal Ruby?
                              I guess it'd be worth compiling this info into a how-to article...
                              • N
                                nikus_knx
                                Did you do this? I can't found it...
                                  I got a Hello World project tutorial over at BitBucket:
                                  https://bitbucket.org/thomthom/sketchup-ruby-c-extension
                                  SCF thread related to the tutorial:
                                  http://forums.sketchucation.com/viewtopic.php?f=180&t=41077
