    Creating Your Own Face In SketchUp
    7 Posts 7 Posters 1.3k Views 7 Watching
      arjunmax09
      Hi everyone ..I want to create my own 3D face in SketchUp using sandbox..to make nose ..cheeks and all...but the problem is if I try to do it..the textures just blows apart..I mean it distorts badly..what should I do?
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • soloS
        Got images/screen grabs to show what you want?
        • GaieusG
          I would be scared to see my own face (you remember it from 2008, Pete...)
          ๐Ÿ˜’
          I don't even shave nowadays as that would require me to look into the mirror!
          ๐Ÿ˜ฎ
            Mary_1.0
            If you don't mind using another software to do it, you could use Poser to create 3D people. It has an option to create a head based on front and side mugshots of someone. Then you just put the head on one of the people from the library, add hair and clothes, export it as a 3ds file and bring it into Sketchup. The person in Sketchup is not poseable, so you'd have to pose them before you export, and they will contain a lot of polygons. I usually put them on their own layer in SU, so I can turn off the visibility when I'm not working with them, so they don't bog down SU too much.
            • T
              tomot
              Alternative solution:
              1. Convert any digital picture to black and white
              2. Import that image into Rhino using import image from Heightfield
              3. Save mesh as OBJ or DXF
              4. Import into SU.
              my plugins
              tomot
              • kenK
                ken
                I have used this program to make a 3d file of my head, it will export as an OBJ file. Fun to use.
                Fastly error: unknown domain 151.101.1.91
                (download.cnet.com)
                Now all you need are two photos.
                Hope this helps.
                I was hoping that TIG importer for OBJ files with material would work, however, I couldn't get it to import at any time.
                404 Not Found
                (forums.sketchucation.com)
                This plugin from TIG does not import the OBJ file.
                Error 404 (Not Found)!!1
                (sketchuptips.blogspot.com)
                This importer from Jim does bring in the file, but with no texture.
                MyHead.skp
                  Jim
                  BTM made some scuplt tools, too that may be useful.
                  404 Not Found
                  But I'd put my money on Thom's vertex editing tools as soon as they are available.
