    Tools -> Fredo6 Collection won't open
    4 Posts 2 Posters 911 Views 2 Watching
    • W Offline
      WagonRanch
      I used to have the FredoScale working on my computer. I added a couple of non-Fredo6 plugins (I know...what was I thinking?) and now the Fredo6 Collection appears on the Tools menu but is unresponsive; when I left or right click on it nothing happens. I have the LibFredo6_Dir_34 folder and it seems to be populated correctly. I also have the ZLoader__FredoScale.rb script in the Plugins folder. I have Joint Push/Pull and the Bezier tools installed and the're working correctly. One thing that I see that may be problematic is that there is only one file in the C:\Program Files\Google\Google SketchUp 7\Plugins\DEFPARAM_Dir, which is "ToolsOnSurface.def", no FredoScale.def like I think there should be. I've reinstalled FredoScale 2.0i, but it didn't do anything. Closed and reopened the program. Rebooted.
      Can somebody help me get my FredoScales working again?
      SU7
      XP Pro. SP3
      3GB RAM.
      • W Offline
        WagonRanch
        A bit more on my LibFredo6 problem that I left out. When I go to Window -> LibFredo6 Settings -> Default Parameters nothing happens.
        Thanks in advance.
          If you open the ruby console, do you see any error messages?
          • W Offline
            WagonRanch
            OK, well I couldn't get any of it to work. All the plugins seemed to be installed correctly in the proper subfolders, etc.
            So, I uninstalled SU 7.1 Pro. Moved the contents of the Plugins folder to a temp folder, including all the zip files that were there. Reinstalled SU 7 Pro. Did the update to 7.1. Moved the zip files back to the plugins folder. Extracted LibFredo6 3.4c first, then the other Fredo6 plugins that I wanted/needed. It all works just fine now. Dunno what happened. "Take it from the top" seems to be the trick.
