    Make_Comonents.rb Version 1.1 Does Not Run All the Time
    5 Posts 2 Posters 1.8k Views 2 Watching
      mac1
      System Windows xp sp3
      SU as noted below
      P4 3.2GHz Intel 865 PERL Mother Board, 4 GB Memory
      I have been attempting to convert the file ref in this link http://www.google.com/support/forum/p/sketchup/thread?tid=50e8ceb670ed94ef&hl=en ( file: http://sketchup.google.com/3dwarehouse/details?mid=5841263f36529eef9f30f02514717f00)to components but the script usually converts the first group and quits but, some times it will convert correctly. Ii have not been able to find the initial conditions to repeat the success case. When the failure occurs the ruby console reports this:
      Error: #<NoMethodError: undefined method definition' for #<Deleted Entity:0x60ad9f0>> F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:140:in make_components'
      F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:135:in each' F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:135:in make_components'
      F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:48
      F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:48:in `call'
      I have uninstalled all ruby scripts except the ones loaded with the basic SU installation also removed SU 6. the failure repeats with both SU 7.0+ and SU 7.1 both with clean installs. I have tried a repair install with both SU 7's but cannot because of a missing msi file
      Any Suggestions??
      • Chris FullmerC
        The ruby script in question appears to be the one written by Matt666:
        404 Not Found
        (forums.sketchucation.com)
        You mgiht even ask this question in that thread. Matt might be quicker to respond if he realizes your asking about his plugin.
          mac1
          404 Not Found
          Will do but not quite sure of protocol so the same thread does not appear two places. Remove here or add ref to the post in your cited thread or ????
          • Chris FullmerC
            Oh it really doesn't matter. If you post in that thread, I can go ahead and delete this thread you don't mind?
              mac1
              go ahead I copied my question to your cited thread, thanks!
