    Float <-> String - Locale aware?
    35 Posts 5 Posters 11.0k Views 5 Watching
      ... I must be going mad. I dunno why I produced that previous hack when a simple replacement of comma to period works.
      I meant to be tackling the other way around...
      Ok - enough ramblings. Time to get some rest.
        No rest for the wicked.
        decimal_separator = 1.2.to_l.to_s.match(/\d(\D)\d/)[1]
        This returns the decimal separator.
        1.23.to_s.tr!('.', decimal_separator)
        And this outputs a float in the user's locale.
        Hacky hacky hacky... 🀒
        Now: how does one do this properly?
          @dan rathbun said:
          We can see if the user is using metric, via:
          Still doesn't say anything about the user's decimal separator though. 😞 Only their modelling units.
          An user with English locale might use a metric template.
          And one can set the decimal separator to anything in the system settings.
          • Dan RathbunD Offline
            Dan Rathbun
            The PROPER Ruby way is to either override a method, or add a new method to the base class. That's why I love Ruby. It's the Dynamic feature of the language.
            Why is it that @Last/Google can override base classes (and do it very poorly/error prone, etc.) and I with 30+ years experience am not supposed to be allowed to?
            Why does noone say anything when Rick Wilson overrides or adds to base classes or Sketchup classes?
            The SKX project is/was a means of proposing/testing such new methods or base class overrides.
            I'm not here much anymore.
              Dan Rathbun
              No, it returns a String representation of a Float, using the user's locale system decimal separator.
              But .tr/.tr! will change ALL occurances of '.', whereas sub/sub! change only the first occurance.
              πŸ˜† picky, picky
                Does it matter?
                  Regardless of who does it, overriding base class method in the SU environment is a no-no. One can not know how it will affect other scripts - they could be relying on the original behaviour.
                  I would love to override existing methods, but that only works if you have the sole control of the environment. And in SU Ruby, you don't.
                  The reason I avoid adding new methods is that one never knows if someone else also adds a method of the same name that does something different. Same problem as before.
                  Now, one could go about and prefix with your initial as the conventions are for root modules. But then again, say you create a a plugin that adds a method to a base class. It turns out to have a bug.
                  You fix that.
                  You then make another plugin with that fix.
                  But the a user could have your new plugin and the old bugged version of your first and it loads last overriding the method. Now you're stuck with the bugged version in both your plugins - because you don't have control over the environment your plugin lives on.
                  Now, this latter case is more of a problem for yourself, so if one want to do so then fine. But I avoid it.
                  But overriding base methods are still a no no.
                  I've seen Rick add to base classes. I've not seen him override base methods though.
                  Because they deploy the platform. They are the source.
                  You, me, everyone else got to try to live along side inside that environment without causing conflicts for each others.
                  Yes - we where even talking with people from Google Sketchup if they thought some of it could cause conflicts.
                  Personally that project ended up being down-prioritised for other projects.
                    Found a nice method:
                    http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#format_degrees
                    It formats any numeral into a string using the user's locale with the model precision.
                    Example, Norwegian locale and 1 digit precision:
                    Sketchup.format_degrees(500.555)
                    Returns the string: "~ 500,6" πŸ˜„
                    Now, if only I could find a method for the other way around...
                      Jim
                      It's OK to extend only specific instances with with some instance methods, and without modifying the base class.
                      Something like...
                      module Translatable
                          def translate(lang)
                              "Hi"
                      str = "Hello"
                      str.extend(Translatable)
                      str.translate("en")
                        Dan Rathbun
                        Called creating a singleton method.
                          Dan Rathbun
                          I don't think I can test the other way as my locale setting uses period as decimal point.
                          If your model units are metric, and your OS locale decimal separator is comma, what happens when you try to use the base class (SU extended) method String.to_l ?
                          Ex:
                          length = "5,43".to_l
                          (1) what does length then appear as in the console ?
                          (2) what does it appear as in an inputbox control ?
                          (3) what does it appear as in a webdialog ?
                          What happens when:
                          length = "5.43".to_l
                            cjthompson
                            Why won't "12,2".to_l.to_f work?
                              Dan Rathbun
                              ...[snip]...
                              What happens when:
                              Sketchup.format_degrees(500,555)
                              Wouldn't you be specifying decimals in euro-format?
                              When I try it there is a conflict; Ruby sees the comma as an argument delimiter, and pukes up an argument (2 for 1) exception.
                                Dan Rathbun
                                I can't test that; it raises an:
                                <ArgumentError: (eval):0:into_l': Cannot convert "12,2" to Length>` because I think of my US-en locale settings.
                                TT will need to test it, with his euro settings.
                                Of course, "12.2".to_l.to_f works just fine for me (and anyone in the US.)
                                  Dan Rathbun
                                  I take that back.
                                  I set Format=Decimal, Units=Millimeters, Precision=0.0000mm, and the value returned (in Inches,) is:
                                  "12.2".to_l.to_f >> 0.480314960629921
                                  which is a precision to 15 decimal places. [FYI: 12.7mm is considered 0.5 inches. You often see 50 caliber weapons expressed as 12.7mm]
                                    0.213779527559055
                                    Because I use metric mm template it also converts the float into inches.
                                    Because .to_s is called upon the Length object.
                                    You'd have to convert it to a string to pass it to a webdialog, so the result would be the same as above.
                                      @dan rathbun said:
                                      What happens when:
                                      length = "5.43".to_l Error: #<ArgumentError: (eval):894:into_l': Cannot convert "5.43" to Length>
                                      (eval):894`
                                        "12,2".to_l.to_f 0.480314960629921
                                        It doesn't work because SU does unit conversion at the same time.
                                          Dan Rathbun
                                          Back to the original question, then:
                                          @thomthom said:
                                          Is there any methods that do these conversions that are locale aware?
                                          Are the Sketchup method extensions to the base classes, locale aware and suit your needs ??
                                          String.to_l
                                          Numeric.to_l
                                            String.to_l
                                            Numeric.to_l
                                            .to_l and Length.to_s is locale aware. But, it does not suit my needs. I'm trying to convert between String and Float, not between String and Length.
                                            As mentioned before:
                                            Sketchup.format_degrees works for Float -> String
                                            It even has the extra benefit of adhering to the model unit's precision.
                                            But for String -> Float (where the string is formatted in the user's locale, which might include decimal separator other than a period) I only have this dirty hack:
                                              # Some locale settings uses the comma as decimal separator. .to_f does not
                                              # account for this, so all commas must be coverted to periods.
                                              def self.string_to_float(string)
                                                # Dirty hack to get the current locale's decimal separator, which is then
                                                # replaced in the string to a period which is what the .to_f method expects.
                                                @decimal_separator ||= 1.2.to_l.to_s.match(/\d(\D)\d/)[1]
                                                string.sub(@decimal_separator, '.').to_f
