    Float <-> String - Locale aware?
    35 Posts 5 Posters 11.2k Views 5 Watching
      @dan rathbun said:
      Yes I understand, but the basic Ruby reason is what I said in my previous post.
      I don't see how multiple assignment has anything to do with parsing strings with commas?
      • Dan RathbunD
        Dan Rathbun
        It doesn't, I was speaking about how Ruby interprets Numeric literals to create Float objects. Basically the comma was already taken as an argument and assignment separator.
        I'm not here much anymore.
          Well yes, but using commas in Numeric literals is not the problem in question.
          It's string interpretation and presentation.
          Here's a terrible hacky way:
          r = 1 / '1'.to_l; x = '1,23'.to_l * r; x.to_f
          Returns 1.23 for the string '1,23' when the locale uses comma for decimal separation.
          But I really would like to use a clean way of doing this.
            πŸ˜’ The spider bots are quick. As I try to google Ruby and locale ware Float <-> String conversion I get this thread at the top of the results. πŸ‘Š
              ... I must be going mad. I dunno why I produced that previous hack when a simple replacement of comma to period works.
              I meant to be tackling the other way around...
              Ok - enough ramblings. Time to get some rest.
                No rest for the wicked.
                decimal_separator = 1.2.to_l.to_s.match(/\d(\D)\d/)[1]
                This returns the decimal separator.
                1.23.to_s.tr!('.', decimal_separator)
                And this outputs a float in the user's locale.
                Hacky hacky hacky... 🀒
                Now: how does one do this properly?
                  @dan rathbun said:
                  We can see if the user is using metric, via:
                  Still doesn't say anything about the user's decimal separator though. 😞 Only their modelling units.
                  An user with English locale might use a metric template.
                  And one can set the decimal separator to anything in the system settings.
                  • Dan RathbunD
                    Dan Rathbun
                    The PROPER Ruby way is to either override a method, or add a new method to the base class. That's why I love Ruby. It's the Dynamic feature of the language.
                    Why is it that @Last/Google can override base classes (and do it very poorly/error prone, etc.) and I with 30+ years experience am not supposed to be allowed to?
                    Why does noone say anything when Rick Wilson overrides or adds to base classes or Sketchup classes?
                    The SKX project is/was a means of proposing/testing such new methods or base class overrides.
                    • Dan RathbunD
                      Dan Rathbun
                      No, it returns a String representation of a Float, using the user's locale system decimal separator.
                      But .tr/.tr! will change ALL occurances of '.', whereas sub/sub! change only the first occurance.
                      πŸ˜† picky, picky
                        Does it matter?
                          Regardless of who does it, overriding base class method in the SU environment is a no-no. One can not know how it will affect other scripts - they could be relying on the original behaviour.
                          I would love to override existing methods, but that only works if you have the sole control of the environment. And in SU Ruby, you don't.
                          The reason I avoid adding new methods is that one never knows if someone else also adds a method of the same name that does something different. Same problem as before.
                          Now, one could go about and prefix with your initial as the conventions are for root modules. But then again, say you create a a plugin that adds a method to a base class. It turns out to have a bug.
                          You fix that.
                          You then make another plugin with that fix.
                          But the a user could have your new plugin and the old bugged version of your first and it loads last overriding the method. Now you're stuck with the bugged version in both your plugins - because you don't have control over the environment your plugin lives on.
                          Now, this latter case is more of a problem for yourself, so if one want to do so then fine. But I avoid it.
                          But overriding base methods are still a no no.
                          I've seen Rick add to base classes. I've not seen him override base methods though.
                          Because they deploy the platform. They are the source.
                          You, me, everyone else got to try to live along side inside that environment without causing conflicts for each others.
                          Yes - we where even talking with people from Google Sketchup if they thought some of it could cause conflicts.
                          Personally that project ended up being down-prioritised for other projects.
                            Found a nice method:
                            http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#format_degrees
                            It formats any numeral into a string using the user's locale with the model precision.
                            Example, Norwegian locale and 1 digit precision:
                            Sketchup.format_degrees(500.555)
                            Returns the string: "~ 500,6" πŸ˜„
                            Now, if only I could find a method for the other way around...
                              Jim
                              It's OK to extend only specific instances with with some instance methods, and without modifying the base class.
                              Something like...
                              module Translatable
                                  def translate(lang)
                                      "Hi"
                              str = "Hello"
                              str.extend(Translatable)
                              str.translate("en")
                              • Dan RathbunD
                                Dan Rathbun
                                Called creating a singleton method.
                                • Dan RathbunD
                                  Dan Rathbun
                                  I don't think I can test the other way as my locale setting uses period as decimal point.
                                  If your model units are metric, and your OS locale decimal separator is comma, what happens when you try to use the base class (SU extended) method String.to_l ?
                                  Ex:
                                  length = "5,43".to_l
                                  (1) what does length then appear as in the console ?
                                  (2) what does it appear as in an inputbox control ?
                                  (3) what does it appear as in a webdialog ?
                                  What happens when:
                                  length = "5.43".to_l
                                  • C
                                    cjthompson
                                    Why won't "12,2".to_l.to_f work?
                                    • Dan RathbunD
                                      Dan Rathbun
                                      ...[snip]...
                                      What happens when:
                                      Sketchup.format_degrees(500,555)
                                      Wouldn't you be specifying decimals in euro-format?
                                      When I try it there is a conflict; Ruby sees the comma as an argument delimiter, and pukes up an argument (2 for 1) exception.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        I can't test that; it raises an:
                                        <ArgumentError: (eval):0:into_l': Cannot convert "12,2" to Length>` because I think of my US-en locale settings.
                                        TT will need to test it, with his euro settings.
                                        Of course, "12.2".to_l.to_f works just fine for me (and anyone in the US.)
                                        • Dan RathbunD
                                          Dan Rathbun
                                          I take that back.
                                          I set Format=Decimal, Units=Millimeters, Precision=0.0000mm, and the value returned (in Inches,) is:
                                          "12.2".to_l.to_f >> 0.480314960629921
                                          which is a precision to 15 decimal places. [FYI: 12.7mm is considered 0.5 inches. You often see 50 caliber weapons expressed as 12.7mm]
                                            0.213779527559055
                                            Because I use metric mm template it also converts the float into inches.
                                            Because .to_s is called upon the Length object.
                                            You'd have to convert it to a string to pass it to a webdialog, so the result would be the same as above.
