Dividing a curved face
I have a built in buffet that hangs off a wall that I'm drawing. In plan view it's a segment of an arch. I need to evenly divide this curved edge. I tryed using the 1001 plugin divider but I can't get it to work. I suspect it's on account of the fact that the curve is segmented. Is there a way to do this ?
Without image or better "skp file" it's some difficult to see something for speedy help
Best would be to make the arch with a segment number that can be evenly divided by the number you want to divide it. As Pilou says, an image (or even better, the model) would be best.
OK, I overlaid a curved segment with the required number and used that as a guide as suggested. Thanks !
