    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 59.7k Views 44 Watching
    • olisheaO Offline
      olishea
      loving it!! left one cooking overnight ๐Ÿ˜„
      oli
      • olisheaO Offline
        olishea
        from the cigarette rendering challenge a while back:
        lets smoke some grass! ๐Ÿ˜Ž
        http://i654.photobucket.com/albums/uu269/olishea/4-1.jpg
        oli
        • F Offline
          flipya
          Nice ones Solo & Oli! ๐ŸŽ‰
            dylan
            Thought I may as well join in the fun.
            http://dmdarchitecture.co.uk/
            • boofredlayB Offline
              boofredlay
              That looks great Oli. Well done sir.
              • michaliszissiouM Offline
                michaliszissiou
                Well done oli. Feel free to post the other one too (you know what LOL)
                I must say that this plug in gives another dimension to SU.
                • majidM Offline
                  majid
                  just have time to play with this.
                    boofredlay
                    That is the best use of the plugin I have seen yet. ๐Ÿ‘
                      d12dozr
                      ๐Ÿ˜ฎ Majid that is awesome!
                      ...too bad SU can't handle more than just that scene ๐Ÿ˜’
                      http://goo.gl/f7ooYh
                        michaliszissiou
                        I ruined michalis' amazing sculpture. Again, sorry mate!
                        This is the new dimension I was talking about. You have shadows turned off, is this too heavy for the imac? ๐Ÿ˜†
                        Food for fun, I also include a low def version of this head. Try to paint the UV texture should be fun too.
                        @majid: epic!
                        romPortrLo.skp.zip
                        • majidM Offline
                          majid
                          there are some trick, as what we could do for a sigle fur component to use it in a mass amount...(for twilight also) then spray it using compo spray, or the fur plugin again,(I guess it is also possible with SU2KT scripct, replace with proxy objects item) here are two raw tests
                          using compo spray
                          using fur plugin
                            boofredlay
                            So would that be a throw pillow or a spray pillow ๐Ÿ˜ฒ
                              Recent archaeological surveys proved that the Great Sphinx in Giza was originally designed somehow like this, too. As it turned out, it was the French when touring in Egypt under Napoleon who burnt its hair.
                              ๐Ÿ˜’
                                sketchnl
                                ๐Ÿ˜† very cool oli ๐Ÿ˜Ž
                                http://www.sketchimpressions.nl
                                • olisheaO Offline
                                  olishea
                                  nice one dylan! although i wouldn't like to sit on it! ๐Ÿ˜„
                                  here is another one. next time I will use high res grass component.
                                  "Morning Dew"
                                  [EDIT] improved grass contrast
                                  http://i654.photobucket.com/albums/uu269/olishea/6-1.jpg
                                  with crude dof blur:
                                  http://i654.photobucket.com/albums/uu269/olishea/6_dof.jpg
                                  [EDIT]: I ruined michalis' amazing sculpture. Again, sorry mate!
                                  http://i654.photobucket.com/albums/uu269/olishea/Picture34.png
                                  oli
                                  • soloS Offline
                                    Bufalo grass.
                                    • olisheaO Offline
                                      olishea
                                      i don't understand what you've done there pete! but it looks sweet!
                                      oli
                                      • soloS Offline
                                        Oli, and anyone that wants it, here it is.
                                        bufalo grass1.skp
                                        And here is the clip map/alpha:
                                          briggs
                                          Wow - It looks absolutely awesome!
                                          I'm currently trying to learn how to get grass into sketchup renders, it would be really helpful if you could just put up a few pointers on how you achieved that image ๐Ÿ˜Ž
                                          • soloS Offline
                                            Briggs, it's pretty simple really, create a plane, import the component you want to populate, select it in the drop down window as the component to populate and enter.
                                            Then in your render app, use the supplied alpha map as the clipmap as it's already UV mapped and will work without fail.
                                            • 4 / 9
