    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 76.5k Views 44 Watching
      dylan
      Thought I may as well join in the fun.
      http://dmdarchitecture.co.uk/
      • boofredlayB Offline
        boofredlay
        That looks great Oli. Well done sir.
        • michaliszissiouM Offline
          michaliszissiou
          Well done oli. Feel free to post the other one too (you know what LOL)
          I must say that this plug in gives another dimension to SU.
          • majidM Offline
            majid
            just have time to play with this.
              boofredlay
              That is the best use of the plugin I have seen yet. ๐Ÿ‘
                d12dozr
                ๐Ÿ˜ฎ Majid that is awesome!
                ...too bad SU can't handle more than just that scene ๐Ÿ˜’
                http://goo.gl/f7ooYh
                  michaliszissiou
                  I ruined michalis' amazing sculpture. Again, sorry mate!
                  This is the new dimension I was talking about. You have shadows turned off, is this too heavy for the imac? ๐Ÿ˜†
                  Food for fun, I also include a low def version of this head. Try to paint the UV texture should be fun too.
                  @majid: epic!
                  romPortrLo.skp.zip
                  • majidM Offline
                    majid
                    there are some trick, as what we could do for a sigle fur component to use it in a mass amount...(for twilight also) then spray it using compo spray, or the fur plugin again,(I guess it is also possible with SU2KT scripct, replace with proxy objects item) here are two raw tests
                    using compo spray
                    using fur plugin
                      boofredlay
                      So would that be a throw pillow or a spray pillow ๐Ÿ˜ฒ
                        Recent archaeological surveys proved that the Great Sphinx in Giza was originally designed somehow like this, too. As it turned out, it was the French when touring in Egypt under Napoleon who burnt its hair.
                        ๐Ÿ˜’
                          sketchnl
                          @olishea said:
                          from the cigarette rendering challenge a while back:
                          lets smoke some grass! ๐Ÿ˜Ž
                          http://i654.photobucket.com/albums/uu269/olishea/4-1.jpg
                          ๐Ÿ˜† very cool oli ๐Ÿ˜Ž
                          http://www.sketchimpressions.nl
                          • olisheaO Offline
                            olishea
                            nice one dylan! although i wouldn't like to sit on it! ๐Ÿ˜„
                            here is another one. next time I will use high res grass component.
                            "Morning Dew"
                            [EDIT] improved grass contrast
                            http://i654.photobucket.com/albums/uu269/olishea/6-1.jpg
                            with crude dof blur:
                            http://i654.photobucket.com/albums/uu269/olishea/6_dof.jpg
                            [EDIT]: I ruined michalis' amazing sculpture. Again, sorry mate!
                            http://i654.photobucket.com/albums/uu269/olishea/Picture34.png
                            oli
                            • soloS Offline
                              Bufalo grass.
                              • olisheaO Offline
                                olishea
                                i don't understand what you've done there pete! but it looks sweet!
                                oli
                                • soloS Offline
                                  Oli, and anyone that wants it, here it is.
                                  bufalo grass1.skp
                                  And here is the clip map/alpha:
                                    briggs
                                    Wow - It looks absolutely awesome!
                                    I'm currently trying to learn how to get grass into sketchup renders, it would be really helpful if you could just put up a few pointers on how you achieved that image ๐Ÿ˜Ž
                                    • soloS Offline
                                      Briggs, it's pretty simple really, create a plane, import the component you want to populate, select it in the drop down window as the component to populate and enter.
                                      Then in your render app, use the supplied alpha map as the clipmap as it's already UV mapped and will work without fail.
                                      • olisheaO Offline
                                        olishea
                                        ah you projected the grass onto that jagged geometry! sneaky sneaky! i wondered what the blue bits were but its just the reverse face, right? ๐Ÿ˜ฒ
                                        looks mint
                                        oli
                                        • soloS Offline
                                          yup, easy as pie.
                                          • W Offline
                                            wyatt
                                            I may be a little slow, but why is the component and clip map upside-down?
                                            • 4 / 9
