    Run Validity Check
    8 Posts 6 Posters 2.0k Views 6 Watching
      Is there a way to trigger the Validity Check via the API?
        MartinRinehart
        I started with SU 7 and the Fix Problems button has never found a problem to fix.
          Jim
          Sketchup.send_action 21124
            After importing
            I run into it some time to time when I import geometry from other formats.
            And after I run my CleanUp script that removes unnecessary edges - I've not found out why that happens. But I want to run that command after a clean up operation to ensure things are as it should.
            Thanks! πŸ‘
            Does it work on Mac as well?
              ryu
              Has someone figured out what the equivalent of send_action 21124 for the mac is?
              Thanks,
              Robert
              • Dan RathbunD Offline
                Dan Rathbun
                There is Sketchup::send_action( "fixNonPlanarFaces:" )
                ... but it may not be the exact same thing.
                I'm not here much anymore.
                • tt_suT Offline
                  tt_su
                  Yea, it's not the same thing. I think fixNonPlanarFaces is a testing action - lots of them are.
                  I'll file a feature request to get the validation check as a proper method in the API
                    Dan Rathbun
                    Thank you, Thomas!
                    πŸ‘
