    Dynamic component formulas resetting?
    Scheduled Pinned Locked Moved Dynamic Components
    7 Posts 5 Posters 1.9k Views 5 Watching
      danbig
      Has anyone had their formulas written in dynamic components disappear?
      I created a DC, wrote formulas for several of the values, and the next time I opened it, there was a set value where the formula used to be.
      • Chris FullmerC Offline
        Hmm, I have not seen that before Dan.
          Jim
          Wouldn't just be the [ =ƒx] button is off? (In the upper-right corner of the Attributes editor dialog.)
            remus
            what jim said. By default it'll always display the straight values, you can either double click on the relevant field to see the formula or click the f(x) button as jim suggested.
              danbig
              I did verify by clicking the display formula button, and by double clicking on the field where the formula is entered, that the formula is gone, and a set value has replaced it.
              I also noticed because the function the formula performs stopped working upon re-open.
              Strange.
                remus
                Could you post the component by any chance?
                • aadbuildA Offline
                  aadbuild
                  I dont know if it is the same thing, but I made some dynamic windows. I needed 3 different versions e.g casement sliding and awning. the windows did not need animation just sizing and costs attached. I made the first DC and basically copied and changed attributes to suit. This works fine when I need all sliding on the job but when I need a combination of several I find that the code reverts back to the original DC file i copied originally. I ended up redoing all 3 versions of windows from scratch, as no matter what I did I could never gethem to work (in the same model anyway)
                  Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                  https://www.plusspec.com
