    Mass material importer
    14 Posts 10 Posters 9.9k Views 10 Watching
      ARCHI_BUM
      Hi all,
      I found this post on the google groups from nov. of 07, when searching for a way to import a group of materials into sketchup. I installed the ruby and it shows up under my plugins drop down. Problem is I cant get it to work. Does anyone have any experience with this particular plugin??? The genesis of my problem is the need for a bunch of sketchy type materials for a black and white presentation i'm preparing in Layout. I was only able to find a set of jpg's hence my need to convert them to .skm files.
      "QUESTION:
      Is there a way to automate a bulk add of a JPG library to the
      SKM library? I've got several hundred material texture images and it
      would be tedious to convert them by hand one by one.
      ANSWER:
      Use the ruby script Mass Material Importer
      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/massmaterialimporter.rb.
      to place an entire folder of images into your In-Model library, which
      you can then save with Save As Library. You'll probably have to tweak
      the scales on the images."
      Thanks for any help!!
      • BurkhardB Offline
        Burkhard
        You'll find also a workaround here
        301 Moved Permanently
        (www.sketchucation.com)
        [http://www.ia-plus.de(http://www.ia-plus.de)]
          putnik
          What do you do about the scale of the imported images? You still have to manually scale every imported image to make it usable, i.e. brick textures (or any patterned texture that is meant to have a certain size in relation to SketchUp model space).
          There are a few SketchUp material libraries floating around the www, that are basically just images with unrealistic scale, and not true material libraries..
          http://keshas.info
            Since I tweaked this so it worked originally, here goes...
            You pick 'Import Materials' off the Plugins menu.
            You'll get a dialog open up.
            Navigate to the folder that contains all of your image files (jpg etc).
            Select one of the files and click OK - the instructions on the dialog's top-bar tell you to do this...
            Because there is no 'get directory' method in SketchUp Ruby the work around is that you select one file and the script works out that file's directory... Then it takes all of the images in that directory and these are added as materials in the Model - open the 'model-tab' in the Materials browser to see them...
            You might need to scale the materials individually...
            You can then 'save_as' pop-out to export these as separate .skm files outside of the one model if you have multiple models needing some of these materials.
            Still works for me...
            • E Offline
              ericschimel
              Is there a way that you can set the default texture size? I see that when you import them, they all come in at 10" x 10".....
              Other then that, sweet plugin!
              -Eric
              http://plugin.sketchthis.net
              Sketchup Kitchen Design Plugin
              Custom Models
                You can read the image size and set the materials texture to suit...
                ### material == mat in the script...
                image_width_in_pixels = mat.texture.image_width
                image_height_in_pixels = mat.texture.image_height
                my_factor = 0.3333333 ### how do we decide this ?***
                image_height_in_inches = image_height_in_pixels * my_factor
                mat.texture.size = image_height_in_inches ### auto-keeping aspect ratio
                ### OR perhaps mat.texture.size = [image_width_in_inches, image_height_in_inches] ### ???
                *** Unfortunately there seems to be no direct relationship between the original image size in pixels and imported image or the texture size it produces. We could find
                path_to_image=mat.texture.filename
                then use Ruby to find its size - as its file-size might come into the equation with it w/h pixel size ?
                file_size=File.size(path_to_image)
                Not sure how though ??? my_factor would then be calculated based on the file_size and image_height in pixels, to return it as inches ?
                To show this weirdness manually you can import two images of different pixel sizes and double-click to place them with no scaling - and an image of 225x225px might become a SUp image of 75x75" when exploded, whilst one 512x512px might become 69x69" - the height:width ratio is kept but the image-size varies - probably depending on the image's complexity, I find that low-res monochrome images import as very large in w/h inches ?
                It's an enhancement I've yet to implement - if you want to add it then it's not so hard - except for working out what the size should be ??? ... ๐Ÿค“
                  Also there is no direct relationship between an image size in pixels and how many virtualinches/sms it should cover in SU (just think of brick sizes -how would the plugin know how many bricks are in the image and how big they are supposed to be each?).
                  It seems that some manual tweaking and rescaling the images cannot be spared in SU.
                  • 3D Modeler3 Offline
                    3D Modeler
                    BTW - WOW ... this is an EXCELLENT Plugin.
                    I wish I had known about this a long time ago but better late than never.
                    This plugin will save me (and others) a HUGE amount of time.
                    I have hundreds of hi-res repeating photo textures that would take hours or even days to import and save one-by-one.
                    With this Plugin/Ruby, I was able to save many in just a few clicks.
                    It's going to get lots of use over the next day or two ... any for hereinafter.
                      tomot
                      I agree, I have a large collection, which I'm willing to share, is it possible to
                      setup a sharing of Materials Repository for .skm files at this Forum?
                      [my plugins](http://thingsvirtual.blogspot.ca/)
                      tomot
                      • KrisidiousK Offline
                        Krisidious
                        Tomot... I don't know but let me know. I'd love to see what you have.
                        I still use the importer and it works somewhat well. I do have issues with it after using it 3 times in a row or using it on folders with over 50 textures it imports them in a black hue or a light gray hue. So I try to keep the folders small.
                        then of course the standard 10" I would at least like it to be 1'x 1'.
                        By: Kristoff Rand
                          tomot
                          I don't want to be accused of stealing this thread, ....sorry!
                          Come to think of it this might not be feasible in this forum.
                          Therefore I would suggest Google Drive as an alternative. It offers 5GB free and its easy to email download links to friends that are interested in cross sharing.
                          My current customized material files are not small?
                          tomot
                            Krisidious
                            I know what you mean...
                            the smaller folder being my .skm's the larger all the originals and stuff I might not have used or converted yet.
                            I would really love and would pay (hint hint) to be able to convert all the files to skms... and keep the folder structure in tact.
                            By: Kristoff Rand
                              tomot
                              [attachment=0:4l1rf0fq]<!-- ia0 -->materials.JPG<!-- ia0 -->[/attachment:4l1rf0fq]
                              It does not take long to make the conversion, all it takes is time ๐Ÿ˜„ Hint: I keep my textures in separate prefixed folders, while keeping the original texture file folder names unchanged. This way I can always copy my texture folders to any new install of SU. Using this procedure your new prefixed folders can be added to my folders under the common Materials folder, or vice versa.
                              tomot
                                charlezzz
                                Thanks a lot guys for the tips ! the script work fine.
                                But really no one have any idea how to batch-adjust the tiling of the material ? Other ways it will take me days to manually adjust each one of them ๐Ÿ˜• (I have like 500 skm tu adjust)
