    Animate components ?
    14 Posts 5 Posters 1.3k Views 5 Watching
    • E Offline
      epfyffer
      Hello everybody,
      I'm a real newbie in Sketchup (I use the free 7 version).
      I can now create quite easyly what I want, and now I just discover the animation and Export as animation functions.
      My question is the following :
      Is it possible to create an animation with let's say 10 scenes, without any change in the position of the camera, but just with insertion of components. I' m actually trying to make a small wideo that could explain the way to build something, so the idea would be tu have on each scene a new part (saved as component) that appear in the animation.
      I tried it, but unfortunately, if I delete or add a component it appears on every other scenes... So when I save my animation, I have on every scene all the component that are available on the last scene.
      Any idea or plugin that could help me ?
      Thanks in advance πŸ‘ πŸ’š
        Hi epfyffer (and welcome to SCF!)
        Sure it is possible. Place all the parts on different layers (only put things that are grouped or components to layers other than Layer 0) and in each scene, set the visibility of the layers according to your needs then update the scene. The below video seems to demonstrate exactly what you are after.
        After the initial section cut animation I exported the scenes one by one with the different parts of the roofing gradually appearing as still images and made the video from these stills with some transition between them.
        [flash=640,500:4zx14dy5]http://www.youtube.com/v/QxiFQtdR344&hl=hu_HU&fs=1&[/flash:4zx14dy5]
        • E Offline
          epfyffer
          ok perfect, thanks, I just tried it and it works perfect. I never worked with layers so a new discover in Sketchup (in fact I tried but never found how it works... 😳 ).
          So last question, now the group (or components) appear without fading, you did your vid with en external editor or is it a function to add transitions (fading) beetween the scenen in the export ?
          Thanks for your help ! β˜€
            The stills were exported individually (actually they are Twilight Renders, not even pure SU output although that would also work of course) and I used Picasa (free) to compile the video with the transition effects (but I guess any video editor could do it).
            SU cannot do the transition effect itself. Something is either there or not. There is no "in-between". If you export stills from SU, best is to export them something like double size of your "final" and resample them in an image editor with fine antialiasing settings.
            • E Offline
              epfyffer
              ok great thanks for your quick answer !
                So please, when done with the animation, let us also see it so post it here!
                πŸ˜‰
                  dylan
                  I recently used a similar method to Gaieus, but mine is straight SU output exports and compiled in Keynote (Powerpoint equivalent)
                  Extremely simple method and very quick.
                  [flash=853,505:1nxle1uv]http://www.youtube.com/v/SYjcCPBCgew&fs=1[/flash:1nxle1uv]
                  http://dmdarchitecture.co.uk/
                    You can also use Mover plug
                    And put the start move of the object out off the final screen
                    so every thing seems arrive for aglomerate πŸ˜„
                    Only problem you must reccord screen with prog like Camstasia
                      Haha. That fire at the end was scary! And it burnt all the colours off the construction, too!
                      πŸ˜„
                      • utilerU Offline
                        utiler
                        [flash=640,500:30c0mjn9]http://www.youtube.com/v/QxiFQtdR344&hl=hu_HU&fs=1&[/flash:30c0mjn9]
                        Hi Csaba, how did you make the section cut show in solid fill black? 😎
                        Just Curious...
                          Hi Andrew,
                          Painted the back faces black. More exactly set the back face colour to black in the Styles dialog. Certainly some consistent face orientation is needed.
                          Unfortunately it is not perfect as certain things either bleed through (as they are inserted components like windows) or cause Z-fighting when components are attached to the others (and what you normally cannot see).
                          However quite satisfactory if you speed it up enough not to be too apparent.
                          πŸ˜‰
                          • utilerU Offline
                            utiler
                            Ahh yes, now i remember reading somethign about doing it that way....
                            Just Curious...
                              TIG has been hinting something about a more developed (or feature rich) version of his SectionCutFace plugin that would do animated cuts, too.
                              πŸŽ‰
                              At least if I did not misunderstand him.
                              (And over the Twilight Render development they have been hinting about section cut rendering in a future release - now I want animated AND rendered sections at the same time!)
                              πŸ˜‰
                              • utilerU Offline
                                utiler
                                SOunds good Gaieus. Seems there are a few goodies on the horizon.....
                                Just Curious...
