    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    You know you're either addicted...
    22 Posts 19 Posters 1.3k Views 19 Watching
      @solo said:
      or trying to orbit a pdf.
      The worst are SU screenshots posted (mostly) in the help areas of the forums. ๐Ÿ˜’
      • boofredlayB Offline
        boofredlay
        I experience the same as well. I keep trying to right click on one of my co-workers and choose Explode.
        • pbacotP Offline
          Yes, if only life had contextual menus.
            KXI System
            I guess the only way to help is to get addicted to something else...
            Games are real easy, I can give you a whole list or two right now.
            Getting the perfect sig is hard...
            Google it!
              jaxcoffee
              @rickgraham said:
              You know you're either addicted to, or need a break from SketchUp when you're driving around looking at stuff and trying to visualize how to do it in Sketchup. It's true! Looking at houses and other object, I immediately go into the thought process of 'extrude that, offset and use the follow me tool, ohh that would work nicely with XYZ ruby'.
              Is there hope for me? ๐Ÿ˜ฒ
              Rick
              Yep! It's called "The Sickness." And as you can see from some of the post, some have it real bad. From one sicko to the next, welcome. You know when you really have it bad, when you write a book about it. That is a sure sign that you are incurable. I think forum moderation is right up there also!!
              They have found one cure though. Drinking massive amounts of coffee seems to help, or at least keeps you doing thing so fast you don't notice. Still working on that one, but have a tentency to lean towards just drinking a lot, no matter what it is. ๐Ÿ‘
              • DanielD Offline
                Daniel
                You know your addicted when...you think just about every office project should be modeled, even doing some of it on your own time, 'cause their isn't enough in the budget to model it, but you know it would look soooo good in 3D.
                My avatar is an anachronism.
                  bytor
                  2 common symptoms are ....... 1) when you see the final construction docs and tell the Project Manager "man that would have looked much cooler if it was modeled in sketchup" and then 2) when you tell that same PM that he wouldn't be so over his production budget for CD's if the designer had explored his options using sketchup in the Schematic phase instead of constantly changing the production drawings through later phases.
                  Dean
                  Find the Cost of Freedom.....
                  • mitcorbM Offline
                    mitcorb
                    Another symptom is a whole bunch of models in progress caused by imagining how you would model this or that and then trying it out, and then somewhere in the process, the challenge fades, or some other more important issue arises, like groceries, or lawnmower, or take out the trash.
                    • leedeeteeL Offline
                      leedeetee
                      Great thread!
                      Glad to hear its not just me ... !
                      Every walk, bicycle ride, holiday or shopping trip I go on, I now think "How would I model that" or "that would look great in google earth".
                      I now actually find myself tailoring bike rides so we gos past a particular church or interesting building. This is great, it means I have got tonnes of photos to model some buildings from, BUT, there's just not enough hours in the day to model them! ๐Ÿ˜ข ....
                      I even had a dream about Fredoscale the other day - I accidentally put rounded edges onto my fiancee's face, she was distraught and I couldn't undo! ๐Ÿ˜ณ
                      • olisheaO Offline
                        olishea
                        haha, dude you are mental. I did, however, try sandbox tools on my cat ๐Ÿ˜•
                        oli
                          ๐Ÿ’š
                          • F Offline
                            flipya
                            You know you need a break when...
                            you're walking through your model to get a user-perspective, round a corner, and the iClone 3d dude standing there scares you so bad you spill your wine all over your keyboard.
                            True story, unfortunately ๐Ÿ‘Š
                              Golden ratios all over the place. Everything constructed of primitives. "Oooh - look how that material reflect the light.". Caustic reflections in my glass by the lunch table have me sitting there turning the glass over and over in the light. ...until I hear the deafening silence of question-marks from my co-workers. You'd think they'd be used to it by now... ๐Ÿ˜’
                                95% of my projects (not just SU projects) are uncompleted. Then again, I have a really high bar for what I consider "complete". I don't like "good enough".
                                • EscapeArtistE Offline
                                  EscapeArtist
                                  You're about 3-4% ahead of me! I'd be lucky if I complete more than 2-3%. I don't know about my standards, I'm probably just lazy!
                                    I have never completed any projects. I simply "abandon" them as "good enough" for the deadline (and the client).
                                    ๐Ÿ˜’
