π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
JavaScript to Empty Something
In my tutorial I've this little loop:
while ( div.hasChildNodes() ) { // empty the div div.removeChild( div.firstChild );This works, but is it just the hard way to do this:
div.innerHTML = ''?
Completely different things, no? One is removing child nodes from a container element, the other is setting the value of a property of an element.
They are the same:
<html><body> <h1> Headline </h1> <button onclick='dump1()'> Dump1 </button> <button onclick='dump2()'> Dump2 </button> <script> function dump1() { alert( document.body.hasChildNodes() ); document.body.innerHTML = ''; alert( document.body.hasChildNodes() ); } function dump2() { alert( document.body.innerHTML ); while ( document.body.hasChildNodes() ) { document.body.removeChild( document.body.firstChild ); } alert( '[' + document.body.innerHTML + ']' ); } </script> </body></html> -
The former used to be the W3C standard way. The latter used to be the non-standard. But as of HTML5 I believe
innerHTMLandouterHTMLare now standard.
Pretty well supported anyway.
