    Creating Components in Cab.rb
    26 Posts 5 Posters 2.9k Views 5 Watching
    • B
      Brendon5374
      We have started a kitchen making business, and I have been elected to the front office: quotes, customer relations, cold calls, MYOB accounts. And now, drawings. They can make their own coffee. I'm drawing the line at coffee. ha ha.
      I shoppped around on the internet and found the best one (user friendly) was free. By far, at least for a beginner!
      Carcasses is the thing I draw up the most that I make little mistakes with. So I wanted to automate it. I found cab.rb in the depot library, and changed the co-ordinates around to suit. I changed the middle panel to a back panel, and changed it around so that the side panels were not extensions of the kickers, etc. I thought I was quite the resoucesful one.
      My problem is that the drawing process and the feel of the the drawing has to reflect the actual cutting and putting together in the workshop. When I do it the slow way without Ruby I draw the lines for a single piece of timber, Select All, Make Component, then move to the next cut. If I do it in that sequence, then a cabinet will be all joined together (like in the workshop), but I will have the ability to highlight each component (each cut of wood), change it, colour it, measure it, or whatever.
      When I use Cab.rb, its like there was never that process, what appears is the whole cabinet as one as-yet single piece. Obviously it would be a waste for me to laboriously go back and select each line and each face of each peice of wood and press the "Make Component" button.
      I'm having trouble knowing the right words so I can search for the answer. Every time I looked up "Make Component" it took me back to the normal menu on the Sketchup page, and not ruby script.
      I hope there is a simple solution. Thanks in advance.
      Here is a bit of the script. I need each panel and each kicker and each door to be a single component:
      model = Sketchup.active_model
      model.start_operation "Create Cab"
      entities = model.active_entities
      group = entities.add_group
      entities = group.entities
      ls=[]   #left panel
      ls[0] = [0, depth, kick]
      ls[1] = [0, depth, height-thick]
      ls[2] = [0, thick, height-thick]
      ls[3] = [0, thick, kick]
      ls_base = entities.add_face ls
      ls_base.pushpull thick
      x = width-thick
      rs=[]   #right panel
      rs[0] = [x, depth, kick]
      rs[1] = [x, depth, height-thick]
      rs[2] = [x, thick, height-thick]
      rs[3] = [x, thick, kick]
      rs_base = entities.add_face rs
      rs_base.pushpull thick
      rp=[]   #rear panel
      rp[0] = [0, depth, kick]
      rp[1] = [0, depth+thick, kick]
      rp[2] = [0, depth+thick, height-thick]
      rp[3] = [0, depth, height-thick]
      rp_base = entities.add_face rp
      rp_base.pushpull -width
      top=[]   #top
      top[0] = [thick, depth-10.cm, height-thick]
      top[1] = [thick, depth, height-thick]
      top[2] = [thick, depth, height-thick-thick]
      top[3] = [thick, depth-10.cm, height-thick-thick]
      top_base = entities.add_face top
      top_base.pushpull width-thick-thick
      btm=[]   #bottom shelf
      btm[0] = [thick, thick, kick+thick]
      btm[1] = [thick, depth, kick+thick]
      btm[2] = [thick, depth, kick+0]
      btm[3] = [thick, thick, kick+0]
      btm_base = entities.add_face btm
      btm_base.pushpull width-thick-thick
      kickf=[]   #kicktoe panel front
      kickf[0] = [0, 4.cm, 0]
      kickf[1] = [0, 4.cm+thick, 0]
      kickf[2] = [0, 4.cm+thick, kick]
      kickf[3] = [0, 4.cm, kick]
      kickf_base = entities.add_face kickf
      kickf_base.pushpull -width
      kickb=[]   #kicktoe panel back
      kickb[0] = [0, depth-4.cm, 0]
      kickb[1] = [0, depth-4.cm-thick, 0]
      kickb[2] = [0, depth-4.cm-thick, kick]
      kickb[3] = [0, depth-4.cm, kick]
      kickb_base = entities.add_face kickb
      kickb_base.pushpull -width
      view = model.active_view
      view.zoom_extents ....
        mac1
        While you are waiting for plugin update consider using http://forums.sketchucation.com/viewtopic.php?f=323&t=14975&hilit=selection+toys%E2%80%A6. This allows for much quicker selection.
          Jim
          In SketchUp, drawing elements are added to an Entities collection. The Model has an Entities collection, and also Groups and ComponentDefinitions.
          So if before each line that has entities.add_[something], if you create a new ComponentDefinition and add the drawing elements to that Entities collection.
          An example:
          ls=[] #left panel ls[0] = [0, depth, kick] ls[1] = [0, depth, height-thick] ls[2] = [0, thick, height-thick] ls[3] = [0, thick, kick] new_definition=Sketchup.active_model.definitions.add("Left Panel") cdef_entities = new_definition.entities ls_base = cdef_entities.add_face(ls) ls_base.pushpull(thick)
          • B
            Brendon5374
            Thanks Jim,
            but I dropped that into the script, and when I ran the plugin it came back with nothing. Nothing appeared. I tried doing just the example you gave - that didn't work - and then each new element the extra lines. I made sure each one was different. ie:
            ls=[] #left panel
            and..
            new_definition=Sketchup.active_model.definitions.add("Bottom Shelf")
            btm_base = cdef_entities.add_face(btm)
            btm_base.pushpull(width-thick-thick)
            Didn't work.
              Jim
              Sorry - it worked, but I seem to have left out the part where you insert the ComponentInstance into the model.
              # Not the cdef_entities... but the model.entities or model.active_entities. entities.add_instance(new_definition, transformation)
              • B
                Brendon5374
                Jim, I know you must be right. But still, I can't get it to work my end.
                Here is the file. If I cut and paste even just your first lines to replace the first piece, nothing comes up when I run the plugin. I put the old lines back, and it works.
                Cabinet
                • B
                  Brendon5374
                  Well, in light of not getting an answer I can use (at least with my knowledge base), I have figured out an inelegant solution for my problem. I have moved each piece .01mm from each other. The side panel is .01mm away from the bottom shelf and .01mm away from the table top, and the back panel...etc. So now I can point the cursor at each piece without the whole assembly being selected, select all, and make a component.
                  Slow, but by making up a plugin, at least all the lines are already drawn.
                  I did have a look at the suggestions, but they just wouldn't work for me, no matter where I put them in the script. And I did try. I tried to look for references and examples, but it was a labynrith on google, and quite often the only link was back here in this thread. LOL I thought it would be easier, since it is a basic action. But this experience for me here has been like asking what the motto says on a school blazer, only to be told to learn the latin language and find out that way.
                  • F
                    Frankn
                    Sorry for digging up an old post but this is exactly the file I'm trying to modify to add components to. As per Dan Rathbun's advice I've read, searched tried to emulate other scripts and I just can't get it to work.
                    I just don't graspe the inner workings of how to create components and the more I search the more I get confused because there seems to be a number of different ways to do this and obviously none of which my ruby newbie brain is understanding.
                    Any help would be greatly appreciated,
                    Frank
                      Jim
                      Frank,
                      First, add a new ComponentDefinition:
                      definitions = model.definitions
                      new_component_definition = definitions.add("Definition Name")
                      Then add geometry to the Definition's Entities:
                      new_component_entities = new_component_definition.entities
                      new_component_entities.add_line([0, 0, 0], [10, 10, 10])
                      Finally, add an Instance of the Definition to the model (or current context)
                      model.active_entities.add_instance(new_component_definition, Transformation.new)
                      • F
                        Frankn
                        Thank you so much Jim for taking the time to answer such a seemingly simple thing to do. πŸ˜„
                        I still get confused with this part...
                        Is the second line equivelent to the following?
                        ls=[] #left panel
                        It's starting to make more sense. πŸ˜„
                        Out of curiosity and in the name of learning how to do things why is this code different then what you gave before, which is what I've been trying to make work?
                        Frank
                        • Dan RathbunD
                          Dan Rathbun
                          For Brenden (and Frank, and whomever...)
                          Get the Cutlister plugin from Dana Woodman (ishboo)
                          ver 1.2: http://www.extendsketchup.com/plugins/cutlister/
                          Note: The one here on SCF is ver 1.1
                          I'm not here much anymore.
                          • Dan RathbunD
                            Dan Rathbun
                            Yes it can be and I (personally,) try not to use method names as reference (ie, variable,) identifiers (although Ruby allows it,) it is very confusing for newbies. I would use a identifier that you would KNOW is a reference, and write the example like:
                            ents_ref = new_component_definition.entities
                            ents_ref.add_line([0, 0, 0], [10, 10, 10])
                            ls=[] #left panel
                            NO. The former produces a single Skecthup::Edge object (adding it to the model, into the current editing context: the Model entities, a Group or Component entities collection, or a sub-Group of a Group... etc.)
                            The latter, adds 12 Edges and 6 Faces.
                            Well don't feel bad.. because Components are in the second semester course. 🀣
                            • F
                              Frankn
                              Thanks for the link Dan, I'll give it a try and see how it compares to CutList 4.1
                              So is it better to use... entities.add_line([0, 0, 0], [10, 10, 10]) ...which is something new I'll have to learn πŸ‘Š then what this script is using?
                              So what you're saying is I'm trying to run before I can walk... πŸ˜†
                              If there's a simple tutorial on components somewhere please point me to it, I'd really like to understand this aspect of scripting because it seems like something I'd use a lot of.
                              Well back to the books/web for me... wish me luck I need it so far what you and Jim have given me causes Sketchup to crash πŸ‘Š 🀣 and I know it isn't the code you've given me but I think it's where I'm placing it into the script...
                              Serenity now!!!
                              Thanks,
                              Frank
                              • F
                                Frankn
                                The more I read about how to create entities (I think I'm using the correct term) the more I realize that this script (cab.rb) probably isn't the best one to learn to script with.
                                Using entries like entities.add_line([0, 0, 0], [10, 10, 10]) seem to be much more useful, also more powerful and maybe even simpler to use when you get how they work.
                                Even if this script does hwta I want it to do, seems like building off of it to get the end result I want is more work then making something from scratch...
                                Back to the reading!
                                p.s. Mods if this is taking this thread off topic let me know and I'll stop posting here. πŸ˜„
                                  Jim
                                  Good point, I've modified my example to avoid the use of a method name as a reference.
                                  • F
                                    Frankn
                                    Hi just wanted to thank you both for taking the time to help me learn something new. I was able to get it to work but I couldn't get this line to work...
                                    model.active_entities.add_instance(new_def_component, Transformation.new) I keep getting this error not sure why.
                                    Error: #<NameError: uninitialized constant Transformation>
                                    But I am able to get it to work with this and it does what I need so far. πŸ˜„
                                    inst = ent.add_instance def_shelf, [0, 0, 0]
                                    I do have a question. I know how to create multiple instances of the same component and even make them unique if I need to... but how can I make the number of instances needed a variable?
                                    Example... user is prompted for the number of boxes he wants to add, he enters 3, the scripts creates 3 boxes in different locations.
                                    Frank
                                    • Dan RathbunD
                                      Dan Rathbun
                                      @frankn said:
                                      ... but I couldn't get this line to work...
                                      Because the Transformation class is wrapped in the Geom module, it is qualified as Geom::Transformation, and you cannot refer to it as simply Transformation unless your code is executing within module Geom (which is a no-no.)
                                      So.. from another namespace (module,) you must qualify the classes, so the interpreter can find them. It's like id'g me as:
                                      Earth::UnitedStates::Florida::Brevard::Dan
                                      Because the 2nd arg to add_instance() takes a Geom::Point3d object, and the API extended the base Array class to be Comparable with both the API Geom::Point3d and Geom::Vector3d classes.
                                      • F
                                        Frankn
                                        Again thank you for the explaination Dan... it almost makes sense to me! πŸ˜„
                                        Something strange is happening with the way the components are being displayed in the Components window in Sketchup. They're all there but there is no preview picture to the components. But if I create a component manually it shows up... an idea why?
                                        I've also been looking into adding components to other components and all I found so far is some refernences to subcomponents and parent components but nowhere did I find how those work?
                                        This has been a greta learning experience and I find half the battle is actually using the correct search terms but I'm getting there!!
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Try refreshing the thumbnails, thru the thumbnail menu (the left hand button with the drop-down.)
                                          • F
                                            Frankn
                                            I had already tried that and it doesn't work, the only way to get them to show up is to edit the component then the preview shows up. Not a big deal but was just curious if I was doing something wrong with the script/code.
                                            Thanks again sir,
                                            Frank
