    Creating Components in Cab.rb
    26 Posts 5 Posters 2.5k Views 5 Watching
      Jim
      In SketchUp, drawing elements are added to an Entities collection. The Model has an Entities collection, and also Groups and ComponentDefinitions.
      So if before each line that has entities.add_[something], if you create a new ComponentDefinition and add the drawing elements to that Entities collection.
      An example:
      ls=[] #left panel ls[0] = [0, depth, kick] ls[1] = [0, depth, height-thick] ls[2] = [0, thick, height-thick] ls[3] = [0, thick, kick] new_definition=Sketchup.active_model.definitions.add("Left Panel") cdef_entities = new_definition.entities ls_base = cdef_entities.add_face(ls) ls_base.pushpull(thick)
      • B
        Brendon5374
        Thanks Jim,
        but I dropped that into the script, and when I ran the plugin it came back with nothing. Nothing appeared. I tried doing just the example you gave - that didn't work - and then each new element the extra lines. I made sure each one was different. ie:
        ls=[] #left panel
        and..
        btm=[] #bottom shelf
        btm[0] = [thick, thick, kick+thick]
        btm[1] = [thick, depth, kick+thick]
        btm[2] = [thick, depth, kick+0]
        btm[3] = [thick, thick, kick+0]
        new_definition=Sketchup.active_model.definitions.add("Bottom Shelf")
        btm_base = cdef_entities.add_face(btm)
        btm_base.pushpull(width-thick-thick)
        Didn't work.
          Jim
          Sorry - it worked, but I seem to have left out the part where you insert the ComponentInstance into the model.
          # Not the cdef_entities... but the model.entities or model.active_entities. entities.add_instance(new_definition, transformation)
          • B
            Brendon5374
            Jim, I know you must be right. But still, I can't get it to work my end.
            Here is the file. If I cut and paste even just your first lines to replace the first piece, nothing comes up when I run the plugin. I put the old lines back, and it works.
            Cabinet
            • B
              Brendon5374
              Well, in light of not getting an answer I can use (at least with my knowledge base), I have figured out an inelegant solution for my problem. I have moved each piece .01mm from each other. The side panel is .01mm away from the bottom shelf and .01mm away from the table top, and the back panel...etc. So now I can point the cursor at each piece without the whole assembly being selected, select all, and make a component.
              Slow, but by making up a plugin, at least all the lines are already drawn.
              I did have a look at the suggestions, but they just wouldn't work for me, no matter where I put them in the script. And I did try. I tried to look for references and examples, but it was a labynrith on google, and quite often the only link was back here in this thread. LOL I thought it would be easier, since it is a basic action. But this experience for me here has been like asking what the motto says on a school blazer, only to be told to learn the latin language and find out that way.
              • F
                Frankn
                Sorry for digging up an old post but this is exactly the file I'm trying to modify to add components to. As per Dan Rathbun's advice I've read, searched tried to emulate other scripts and I just can't get it to work.
                I just don't graspe the inner workings of how to create components and the more I search the more I get confused because there seems to be a number of different ways to do this and obviously none of which my ruby newbie brain is understanding.
                Any help would be greatly appreciated,
                Frank
                  Jim
                  Frank,
                  First, add a new ComponentDefinition:
                  model = Sketchup.active_model
                  definitions = model.definitions
                  new_component_definition = definitions.add("Definition Name")
                  Then add geometry to the Definition's Entities:
                  new_component_entities = new_component_definition.entities
                  new_component_entities.add_line([0, 0, 0], [10, 10, 10])
                  Finally, add an Instance of the Definition to the model (or current context)
                  model.active_entities.add_instance(new_component_definition, Transformation.new)
                  • F
                    Frankn
                    Thank you so much Jim for taking the time to answer such a seemingly simple thing to do. πŸ˜„
                    I still get confused with this part...
                    Is the second line equivelent to the following?
                    ls=[] #left panel
                    ls_base = entities.add_face ls
                    ls_base.pushpull thick
                    It's starting to make more sense. πŸ˜„
                    Out of curiosity and in the name of learning how to do things why is this code different then what you gave before, which is what I've been trying to make work?
                    Frank
                    • Dan RathbunD
                      Dan Rathbun
                      For Brenden (and Frank, and whomever...)
                      Get the Cutlister plugin from Dana Woodman (ishboo)
                      ver 1.2: http://www.extendsketchup.com/plugins/cutlister/
                      Note: The one here on SCF is ver 1.1
                      I'm not here much anymore.
                      • Dan RathbunD
                        Dan Rathbun
                        Yes it can be and I (personally,) try not to use method names as reference (ie, variable,) identifiers (although Ruby allows it,) it is very confusing for newbies. I would use a identifier that you would KNOW is a reference, and write the example like:
                        ents_ref = new_component_definition.entities
                        ents_ref.add_line([0, 0, 0], [10, 10, 10])
                        ls=[] #left panel
                        NO. The former produces a single Skecthup::Edge object (adding it to the model, into the current editing context: the Model entities, a Group or Component entities collection, or a sub-Group of a Group... etc.)
                        The latter, adds 12 Edges and 6 Faces.
                        Well don't feel bad.. because Components are in the second semester course. 🀣
                        • F
                          Frankn
                          Thanks for the link Dan, I'll give it a try and see how it compares to CutList 4.1
                          So is it better to use... entities.add_line([0, 0, 0], [10, 10, 10]) ...which is something new I'll have to learn πŸ‘Š then what this script is using?
                          So what you're saying is I'm trying to run before I can walk... πŸ˜†
                          If there's a simple tutorial on components somewhere please point me to it, I'd really like to understand this aspect of scripting because it seems like something I'd use a lot of.
                          Well back to the books/web for me... wish me luck I need it so far what you and Jim have given me causes Sketchup to crash πŸ‘Š 🀣 and I know it isn't the code you've given me but I think it's where I'm placing it into the script...
                          Serenity now!!!
                          Thanks,
                          Frank
                          • F
                            Frankn
                            The more I read about how to create entities (I think I'm using the correct term) the more I realize that this script (cab.rb) probably isn't the best one to learn to script with.
                            Using entries like entities.add_line([0, 0, 0], [10, 10, 10]) seem to be much more useful, also more powerful and maybe even simpler to use when you get how they work.
                            Even if this script does hwta I want it to do, seems like building off of it to get the end result I want is more work then making something from scratch...
                            Back to the reading!
                            p.s. Mods if this is taking this thread off topic let me know and I'll stop posting here. πŸ˜„
                              Jim
                              Good point, I've modified my example to avoid the use of a method name as a reference.
                              • F
                                Frankn
                                Hi just wanted to thank you both for taking the time to help me learn something new. I was able to get it to work but I couldn't get this line to work...
                                model.active_entities.add_instance(new_def_component, Transformation.new) I keep getting this error not sure why.
                                Error: #<NameError: uninitialized constant Transformation>
                                But I am able to get it to work with this and it does what I need so far. πŸ˜„
                                inst = ent.add_instance def_shelf, [0, 0, 0]
                                I do have a question. I know how to create multiple instances of the same component and even make them unique if I need to... but how can I make the number of instances needed a variable?
                                Example... user is prompted for the number of boxes he wants to add, he enters 3, the scripts creates 3 boxes in different locations.
                                Frank
                                • Dan RathbunD
                                  Dan Rathbun
                                  @frankn said:
                                  ... but I couldn't get this line to work...
                                  Because the Transformation class is wrapped in the Geom module, it is qualified as Geom::Transformation, and you cannot refer to it as simply Transformation unless your code is executing within module Geom (which is a no-no.)
                                  So.. from another namespace (module,) you must qualify the classes, so the interpreter can find them. It's like id'g me as:
                                  Earth::UnitedStates::Florida::Brevard::Dan
                                  Because the 2nd arg to add_instance() takes a Geom::Point3d object, and the API extended the base Array class to be Comparable with both the API Geom::Point3d and Geom::Vector3d classes.
                                  • F
                                    Frankn
                                    Again thank you for the explaination Dan... it almost makes sense to me! πŸ˜„
                                    Something strange is happening with the way the components are being displayed in the Components window in Sketchup. They're all there but there is no preview picture to the components. But if I create a component manually it shows up... an idea why?
                                    I've also been looking into adding components to other components and all I found so far is some refernences to subcomponents and parent components but nowhere did I find how those work?
                                    This has been a greta learning experience and I find half the battle is actually using the correct search terms but I'm getting there!!
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Try refreshing the thumbnails, thru the thumbnail menu (the left hand button with the drop-down.)
                                      • F
                                        Frankn
                                        I had already tried that and it doesn't work, the only way to get them to show up is to edit the component then the preview shows up. Not a big deal but was just curious if I was doing something wrong with the script/code.
                                        Thanks again sir,
                                        Frank
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Oh are these YOUR components ?? (ie, NOT Google supplied components,) that your having problems with?
                                          See API: ComponentDefinition.refresh_thumbnail
                                          cdefs = Sketchup.active_model.definitions
                                           cdefs.each {|comp| comp.refresh_thumbnail }
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Also..
                                            1. open the Model Info dialog.
                                            2. Go to the File panel.
                                            3. check the "Redefine thumbnail on save" option
