    Command button gives Start pane not "+" sign.
    5 Posts 3 Posters 331 Views 3 Watching
      Dadoing
      I am frustrated by little puzzlers getting onto the SU learning curve. I made a rectangle, pulled it into a solid 3D shape, and then converted it to a component. Now I want to copy it and move the copy precisely 2 feet away on the green (Z) axis.
      1. I clicked on the arrow to change the cursor to an arrow.
      2. I selected the component.
      3. I clicked on the 4-way Move arrow to change the cursor to that.
      4. Then, according to Help, I can click the Windows Command button to add a "+" sign to the 4-way arrow cursor. But when I click the Command button, all I get is the usual Windows Start pane (or whatever it's called).
      5. ??? Thanks.
      Problem with Sketchup is it's more fun than cleaning up sawdust and sharpening tools.
        I don't know what help gives that suggestion (maybe that's for the Mac). Use the Ctrl key to modify the Move (or Rotate) tool to not only move (rotate) but also leave the original in place (i.e. "Move-copy" or "Rotate-copy") on Windows.
          Dadoing
          Thanks, right after I posted, I finally noticed the context-sensitive key suggestions bottom left and noticed the Ctrl key hint.
          This is the quote from the offical Help page at http://sketchup.google.com/support/bin/answer.py?answer=94866
          "Making copies. As mentioned previously, the Move tool can be used to make copies of entities within your model. To make copies of an entity using the move tool:
          Select the Select tool (). The cursor will change to an arrow.
          Select the entities to be copied.
          Select the Move tool (). The cursor will change to a four-way arrow.
          Press and release the Command (Microsoft Windows) or Option (Mac OS X) key on your keyboard. The cursor will change to a four-way arrow with a plus sign. This action informs Sketchup that you want to duplicate the selected entities."
            Aha!
            Thanks - you are right. And yes, I remember that typo on that page - we have even reported it to Google already but they must have missed to correct it.
            • Jean LemireJ Offline
              Jean Lemire
              Hi folks.
              The red axis is the X axis, the green axis is the Y axis and the blue axis is the Z axis.
              Just ideas.
