    HELP setting up a SU code editor
    97 Posts 11 Posters 8.0k Views 11 Watching
      driven
      @dan rathbun said:
      That IS interesting John.
      By running in Alex's Code Editor, only Alex's Code Editor is being debugged.
      Hi Dan,
      I've been using it to help debug Chris Glasier's nSet for Mac use, but in the process I tried it on 3 or 4 WebDiolog
      based rubies and it seems a very useful debug tool, for that type of interactive ruby that is popular... and usually PC only. it does report .rb errors (in relation to itself)
      I was actually trying to put syntax highlighting into RCE using a similar approach, and though I'd try this as a practice run. I should point it to my url.local and run more features, but I haven't stopped using it long enough yet...
      has any one tried Ruby-Mine yet??
        Afraid not. The last week I was deep into getting to grips with C programming.
        So much to try out - so little time. 😞
        • chrisglasierC Offline
          chrisglasier
          This relates to FireBugLite.
          Can anyone tell me why this happens:
          and how to change what so I can see the code.
          • Dan RathbunD Offline
            Dan Rathbun
            @Chris: Do you have nsetWebDialog.set_full_security= true or false ??
            (It defaults to false if you don't explicitly set it.)
            I'm not here much anymore.
              Dan Rathbun
              @Chris: In your webpage for nset, it would easier if you assign an ID to the SCRIPT element(s) that load the external javascript files.
              %(#804000)[<SCRIPT ID='nset_core_js' LINK='..path../core.js'>]
              Then in Firebug Lite, try inspecting by ID. Enter the ID name in the inspect control box. If that doesn't work, try entering:
              document.getElementById('nset_core_js')
                Dan Rathbun
                Firebug page(s) to bookmark:
                http://getfirebug.com/wiki/index.php/Main_Page
                http://getfirebug.com/wiki/index.php/Firebug_Lite
                Forum - Google Groups [EDIT-Added]
                http://groups.google.com/group/firebug
                  Dan Rathbun
                  Access to restricted URI denied
                  I suspect what's happening, is MSIE copies the code into the "Temporary Internet Files" folder, which is usually a Restricted Sites Zone (security-wise.) I've tried (in the past,) to add a specific local folder to my "Trusted Sites Zone" but MSIE refuses.
                    chrisglasier
                    @dan rathbun said:
                    ... but MSIE refuses.
                    Thanks for all your suggestions, which I tried ... but as you said MSIE refuses. No FireBugLite at the end of the tunnel.
                    Thanks again.
                      Dan Rathbun
                      @Chris !!
                      I think I was always trying the wrong thing! I was supposed to be adding the local folder to the LIZ ("Local Intranet Zone".)
                      I stumbled upon this paper:
                      http://msdn.microsoft.com/en-us/library/bb250483(v=VS.85).aspx
                      So retry, go to Internet Options > Security (tab)
                      Hilight "Local intranet", click the "Sites" button.
                      On the "Local Intranet" dialog, click the "Advanced" button.
                      See if the folder (beginning "file://") to your JS code is in the "Websites:" list, if not, add it.
                      See if that helps FirebugLite find your JS scripts.
                        chrisglasier
                        Thanks Dan I will try that and let you know (I'm at GMT + 8 btw)
                          chrisglasier
                          Here's what I got in IE:
                          and still access denied in FireBugLite
                          So I don't know
                            Chelmite
                            I did a search on the aptana site for "sketchup" and didn't find anything.
                            Are there any installation instructions on how to pair up aptana and sketchup?
                            @thomthom said:
                            That's an interesting article.
                            You can download Aptana Studio and RadRails, but the installation process is long and complicated. Besides, if you just want a Ruby editor, downloading a 30-day evaluation version of the gigantic Aptana Studio isn't worth it.
                            Complicated installation process? And the thing is free. http://www.aptana.org/
                            Anyway - are you able to set breakpoints etc in SU plugin scripts and run them from Eclipse?
                            • 4 / 5
