    Small 'line edges' adjustment but will not disappear
    4 Posts 2 Posters 322 Views 2 Watching
      jacm
      I had the '1st floor' temporary 'grouped' and placed it for alinement with ground floor and staircase.
      Some minor adjustments where needed on the frist floor so I made it 'edit group' move walls and opened a rectangled section where the staircase would go through. when complete I returned the floor to 'grouped' and started to check that everything was OK. I've included 2 photos of the 1 st floor, 1 complete and 1 hidden and found lines of where I had done the adjustments. I have tried all ways to erase them but with no sucess, even after purging them a number of times. I have learnt from mistakes that purging is a must always. Can you help please.
      John
      1st flr. complete and grouped
        jacm
        I wish I new how to handle these 'atachments'. I going to sent the second photo!
        second time - I pressed the '+' but it didn't transfer
        • X
          xrok1
          delete the group. or if you need these lines, edit the group and cut them then goto the group where they should be ,edit and paste in place.
            jacm
            I sat last night and thought about what I had done then suddenly it came to me. The floor was originated when I grouped then and put them in 'Layer 30'. I had to make a few adjustments and as usual made then on layer 0. I must get used to 'layer 0' to work on THEN REMEMBERING to transfer, in this case, 'layer 30' - I didn't do that. That was the problem so I've got it sorted now.
            Thanks for your assistance xrok1
            John
