    Retrieve the size of bounding box of selection
    23 Posts 8 Posters 4.1k Views 8 Watching
    • Chris FullmerC Offline
      The visual bounding box is not the actual bounding box returned by Ruby. So what you see is not that Ruby shows. And I do not know if anyone has determined exactly what that offset is. I think it might be a number of screen pixels approximately. Or maybe just a percent of the actual bounding box - 105% larger or something. But I think it changed recently too. Seems like some bounding boxes in 7.1 dob't have any offset anymore?
      • mitcorbM Offline
        mitcorb
        Quote by CF: "The visual bounding box is not the actual bounding box returned by Ruby."
        Oh No Did you have to tell me that?!?!?! If you thought I was lost before....
        Let's just suppose that the box is truly measurable in some set of units. Now, again, what sorts of ways can you apply this information?
          tonradoo
          Thank you for the effort. I tested and encountered a problem with the method by Chris (coded by Jim):
          @jim said:
          What Chris said:
          > bb = Geom;;BoundingBox.new
          > Sketchup.active_model.selection.each { |e| bb.add(e.bounds) }
          bounds is not a method of Entity and hence the code failed to execute. Should I step into each entity to retrieve DrawingElement objects in order to get the BoundingBox?
          On the other hand, I tested TIG's codes and replaced center=ssg.bounds.center by the followings to check the size of the box:
          puts "Width; #{ssg.bounds.width}\nHeight; #{ssg.bounds.height}\nDepth; #{ssg.bounds.depth}"
          These are the results (Tested with my SU Pro 7.0.10247):
          Without Sang:
          ===== Without Sang ====
          Width; ~ 12' 7/8"
          Height; ~ 9' 5 1/2"
          Depth; 6' 11 3/4"
          With Sang:
          ==== With Sang =====
          Width; ~ 12' 7/8"
          Height; ~ 9' 5 1/2"
          Depth; ~ 11' 6 1/2"
          I just wonder why:
          (1) bounds.depth returns the height and bounds.height returns the depth...?
          (2) Sang affects the bounding box in depth that much...
            For 'historical reasons' the bounding-box width/depth/height is not x/y/z as you might expect - it follows another [earlier] 3D protocol where the three dimensions are considered as coming 'out of the screen' rather that in a conventional way of 'looking at the object'... once you get your head around how they are transposed and use them accordingly it's less painful ! πŸ˜’
            I don't know why Sang does that - what is 'his' bounding-box like on its own ?
            If you select all of the objects including Sang and Group them is the bb the same ? πŸ˜•
              Jim
              Since all Drawingelement's have a bounds, did you look for what type of entity was encountered that caused the error? I have seen Loop objects occur in the Entities collection; although I am not sure why they sometimes are present.
              Use this:
                bb.add(e.bounds) if e.respond_to?("bounds")
              • Dan RathbunD Offline
                Dan Rathbun
                Are you saying that if a user orbits the view, say 90 degrees, that the height, width and depth methods may return different (or shuffle) the dimensions ??
                OR is it that the method name 'adjectives' refer to the dimensions as viewed from the Top view (similar to dialog box dimensions) ??
                I'm not here much anymore.
                  Usually, we'll now think of a standard 3D view somewhat as we 'see' it in the real world... with 'height' being 'up' [z/blue] on the screen, and the 'width' being taken left-to-right [x/red] and the 'depth' being taken front-to-back [y/green].
                  and the screen vertical being 'height' [y] (as in 2d or x/y axes on a sheet of paper) and the 'extra' dimension of 'z' was taken as 'depth' - as we were to think of looking down onto the object drawn in plan x/y as it was on paper with it extruding out of the screen into the third dimension...
                  The bounding-box method returns height/width/depth based on these ideas, rather than the current xyz/rgb orientations.
                  So to transpose them perhaps think of the bb.width as x, bb.height as y and bb.depth as z ???
                  Orbiting doesn't change the xyz/rgb or the bb's whd - you are just looking at them from a different view point !
                  Confused you will be πŸ˜• πŸ˜’
                    Dan Rathbun
                    @tig said:
                    So to transpose them perhaps think of the bb.width as x, bb.height as y and bb.depth as z ??? [edited to avoid further confusion:TIG 😳 ]
                    I think you confused yourself. You said they were based on the 'old' protocol.
                    And I DO want to ALIAS them, and make .x, .y and .z methods for the BoundingBox class, and be done with the confusion over what the names (height, width and depth) mean.
                    So wouldn't bb.height be same as bb.y, and bb.depth same as bb.z ??
                    And why do you always put question marks and the end of ALL your statements when they are not really questions ??
                      Jim
                      The Bounding Box of a Face-Me component does change as you orbit.
                      If you Rotate a component, its bb dimensions are shuffled. BB dimensions are relative to SketchUp's "world" axes. The bb.width is always along the "world" X axis. If the Axes have been repositioned, the bb does not use the new Axes, but still uses the "world" axes.
                      It's an interesting experiment to plot the BB corners of a component from a ViewObserver.
                        My typo[s] 😳
                        I have corrected the original[s] to suit... to avoid confusing anyone πŸ˜’
                        I type '??' at the end of some text to avoid me having to type in an actual question. The more ?s the more I question it [???] πŸ˜‰
                        e.g.
                        'It is like that ??'
                        'It is like that, isn't it?'
                        When, 'It is like that.' is a statement of fact !
                        I know I could type the longer, 'Isn't it like that?'... but I didn't realize that the 'style' police had their agents everywhere πŸ˜‰
                        It is equivalent to raising the voice in conversation without having to add the actual question ?? [== isn't it?]
                        Sometimes my flow of consciousness outstrips my typing abilities - as you have noticed...
                          Dan Rathbun
                          Shuffled ?? or just change in magnitude (value)?
                          Can I or Can't I then do this? (And have the aliases always return the correct dimension?)
                          class Geom;;BoundingBox
                            def x
                              self.width
                            def y
                              self.height
                            def z
                              self.depth
                          end # class
                            Dan Rathbun
                            @tig said:
                            ... sometimes my flow of consciousness outstrips my typing abilities - as you have noticed...
                            Just was beginning to wonder whether you had any confidence at all in the things you've been saying. ❓
                              Jim
                              Changed, not shuffled.
                              So no, you can't. The bounds are not relative to the instance, but to the container of the instance.
                              I was thinking if the instance was rotated 90 deg. around Z, then x and y dimensions would be swapped, but that is a specific case.
                                Surely for a rotated instance the bb [ .bounds] is read relative to the model's world axes [or it's container's axes??] ?
                                Clearly Rotating/Scaling a component-instance will change its individual bb, but its definition bb is always unchanged ?
                                So you can find one or the other depending on what is needed...
                                  Dan Rathbun
                                  But that's OK then, because AFTER the rotation, the x of the object's BB is "what it is" NOW regardless of was it was before. It IS the x dimension, at the time of the .x method call. And .height and .width would be swapped as well, correct ?
                                  What I am wanting is a y method that returns the y dimension of the BB, at the time of call.
                                    Magnifico
                                    Nice all this but, i am new in ruby, how can i retrieve the size of all component... including sub-component?
                                    ` mod = Sketchup.active_model # Open model
                                    ent = mod.active_entities # All entities in model
                                    message = ""
                                    ent.each { |e|
                                    n = e.name
                                    scale_x = ((Geom::Vector3d.new 1,0,0).transform! e.transformation).length
                                    scale_y = ((Geom::Vector3d.new 0,1,0).transform! e.transformation).length
                                    scale_z = ((Geom::Vector3d.new 0,0,1).transform! e.transformation).length
                                    bb = nil
                                    if e.is_a? Sketchup::Group
                                    bb = Geom::BoundingBox.new
                                    e.entities.each {|en| bb.add(en.bounds) }
                                    elsif e.is_a? Sketchup::ComponentInstance
                                    bb = e.definition.bounds
                                    if bb
                                    dims = [ width = bb.depth * scale_x, height = bb.width * scale_y, depth = bb.height * scale_z ]
                                    message = message + "Cabinet: " + n + "\nHeight: #{dims[0].to_l}\tWidth: #{dims[1].to_l}\tDepth: #{dims[2].to_l}"
                                    UI.messagebox(message, MB_MULTILINE)`
                                    I would like to have dimensions of all pieces of the cabinet.
                                    I know Cutlist. But i only need name of piece and dimensions.
                                    And Cutlist script is to complicated for me.
                                    Someone can help me with this? PLZ
