Thickness or Shell Ruby... Thanks Fredo6
I was wondering if it is possible to create a shell or thickness Ruby. I thought it might be based on the existing Scale command, whereby the exterior faces would remain on the original exterior faces, while all interior faces (mesh) would be rescaled ?
jointpushpull will do this
search for it. -
The famous Batwings or similar who give some headache when you try to understand these surfaces
sometimes you remind me of granpa Simpson, when he starts rambling about something totally bizarre and no one knows what it has to do with the current conversation.
Torolf is a specialist of these sort of things
I am grampa Simpson
Tomot, So how did you make the model of the image you uploaded, is it flawed? Did joint push-pull work?
looks like a scaled copy.
xork1: Its an inside joke between me and Frenchy.
Frenchy: Yes Ken Barkke provides the only answer. But Torolf is NOT a specialist, he adds nothing new, except to make something look pretty, and with access to enough software and hardware we can all make anything look pretty.
so... did you try JPP?
The interior skin was created with another program, then the entire model was imported to SU.
No, I have not used joint push-pull yet. (I hope joint push-pull is not expecting me to push-pull each face individually in this 3d mesh?)
no, it does them all!
Help me out please!
joint push-pull......yields no search results....... No suitable matches were found. -
you'll be amazed. one of the best plugins out there!
http://forums.sketchucation.com/viewtopic.php?f=323&t=6708&hilit=joint -
@tomot said:
Help me out please!
joint push-pull......yields no search results....... No suitable matches were found."join push-pull" in the SCF searchbar gets translated to
"+join +push -pull" - everything including "pull" will be ignored. That's why it didn't show up in your search results.
i just searched "joint" and found it listed right after this thread.
http://forums.sketchucation.com/viewtopic.php?f=323&t=6708&hilit=jointYour right on xork1
c'est incroyable!
thanks so much Fredo6!
This exist for more 2 years
