    Built walls are are exact height, but there not??
    28 Posts 8 Posters 1.9k Views 8 Watching
    • W
      wyatt
      I wonder if parts of your model have been skewed off of the normal vertical-horizontal planes. Try turning on Color by Axis (Window/Styles/Edge). If the vertical wall lines are not blue (vertical), this could account for the small errors.
      Wyatt
        jacm
        Never used it yet, I forgot all about it. I'll give it a try, thanks
        John
          jacm
          Wyatt
          I have pust pernt how to turn the 'paint bucket' around for part of my floor covering, i.e. 'floorboards'. I may have something to do with it as I don't think I was accurate with the 90 degree turn. I'll double check that as well.
          Thanks John
            jacm
            I've tried all the suggestions that have been given to me today so thanks for your input, its stopped me from going insane.
            I have taken yet another 'snipping tool' photo to show the problem.
            To recap, at the start many weeks ago I made the base, I then started to build the walls. They where doubled checked of each walls hieght and they where all 7feet 6inchestall exactly. Starting in the centre of the building, the staircase, and working out gradually building each wall and again checking the hieght. I entered each mearurement on the keyboard 7'6" and pressed 'enter' to make sure it was exact.
            Two days ago I came across the problem of some walls each where exactly 7'6" but when to gether there was a difference. I repaired to problem and then found another wall with a problem, this time 1 wall was 7'6" and the other was 7' 5 7/8", a difference of an 1/8". so now I keep trying to lay floors, some places O.K. but some places won't align so it becomes difficult and time wasting, makes me feel I'm going round in circles. So I ask the question dump it all and start again, (a loss of quite a few weeks weeks work). Or can somebody got a solution so that I can carry on?
            one wall 7ft6ins the other 7ft 5 7/8ins but they didn't start like this
            • Jean LemireJ
              Jean Lemire
              Hi John, hi folks.
              If your file is too big, first make sure that there are not a lot of textures that you may have used but that are now unused. These textures stay in the file, although they are not being used and they can add to the file size. You can purge these using the purge feature built in the Material dialog box.
              The same applies to components and also to layers.
              Or, you can do a global purge using "Menu Window --> Model info --> Statistics --> Purge Unused".
              If, after doing that, your model is still to big (more than 1 Meg), try this procedure:
              1 - Select only the part of the model that is causing the problem.
              2 - Copy it with CTRL-C. CTRL stands for the "control" key.
              3 - Open a new instance of SU (on PC) or a new file (on Mac).
              4 - Paste using CTRL-V.
              5 - Save the new model. This one shall not be too big.
              Without the actual SKP file, it is very difficult to diagnose your problem.
              Just ideas.
                jacm
                @jean lemire said:
                Hi John, hi folks.
                Just ideas.
                Hi 'J'
                I won't be able to show off my house when its finished because it will be very large indeed.
                I found out that I could sent a small section that may be helpful at the moment. But I will also try your method as well and see if I make it work for me, (I'll probably break it πŸ˜‰)
                I'll sent it for a trial.
                Thanks John
                upload page.skp
                  jacm
                  hi 'J'
                  I tried your method and it said that it was sucessful but when I sent it only the message went through.
                  I did one of my 'snipping tool' I've used it today but will my house front be too big?
                  John
                  I'l try this one
                  • kenK
                    ken
                    Hello
                    Have you checked your unit length precision in the model info? Bet you have it set to something beside 1/64", like a 1/4" or 1/8".
                    Ken
                    • honoluludesktopH
                      honoluludesktop
                      John, It seems that you have a lot of stray edges in your model. Perhaps from editing. When I started to build complex models, I made a lot of mistakes, and had difficulty lining up stuff. I got better over time, but whenever I experiment, rush, and do not save, I end up with unfixable problems. With my early models, I lived with my mistakes, or rebuilt the model when necessary. 1/8" may not be a big deal, just like with real buildings :-), add a trim. Sorry if it seem like I am making "light" of the situation, but I am not. I was really frustrated too. Don't know about others, but my work still suffers from errors.
                        jacm
                        Hello
                        Ken
                        Hi Ken
                        I think the measurement go to 1/8" although 1/16" is shown. I pondered with going low to 1/64" but I decided against it, good or bad decision I don't know.
                        I felt more compfortable with imperial as I was brought up with it but my work has all gone metric and admittedly is easier to use. When I retired I drifted back to imperial but when I started SU I should have gone with metric. I did mention to a member of the forum that on hind sight, I will go "foreign", this 'old dog' should learn new tricks.
                        John
                          jacm
                          @chrisglasier said:
                          Also have you made the walls components?
                          Hi Chris
                          Sorry I must have missed your reply. When I started my prodject the walls where the first thing that I was building. At that time I wasn't knowledgeable about groups and components but I'd learn as I went along. Famous saying "don't run before you've learnt to walk", how true. If I had made them into components from the start I could have myself a lot of problems.
                          Lesson learnt, and a lot more to learn.
                          Thanks for lesson
                          John
                            jacm
                            Hi, Englanddesktop here.
                            Thanks for your pep talk, I'm not the only person in the world with a SU problem. I had unfounded reason for doubting my ability. When this problem is solved by others or myself, there will be others. I will more than likely have other problems and mistakes but I have learnt a lot, maybe the hard way. It's nice to get help when you or I get an "unsolvable" problem.
                            Thanks very much for your input.
                            John
                            • 2 / 2
