    Built walls are are exact height, but there not??
    28 Posts 8 Posters 2.4k Views 8 Watching
      d12dozr
      John,
      Please see this screen grab for where to attach your file. When you have located the file and attached it, click "Add the File", then "Submit"
      http://goo.gl/f7ooYh
        jacm
        @d12dozr said:
        John,
        I think I have sent the file although it was big and took a long time to transfer. I don't even know if it transfered at all.
        (Ignorance isn't bliss)
        John
        • GaieusG
          Hi John,
          No, unfortunately it1s not uploaded. Try again, please. What is the file size?
          • chrisglasierC
            chrisglasier
            Go metric - you're in Blighty.
              jacm
              I am an imperial person of that age but yes I should have gone matric because it is easier. Unfortunately even if I had gone metric it doesn't solved my problem.
              Your right though, I'll go metric in the future. But at the moment?
              John
                jacm
                @gaieus said:
                Hi John,
                I don't know but I'll find out. Meanwhile I'taken 2 photos with 'snipping tool'. I will try to send them in jpeg. Here's hoping.
                John
                  jacm
                  @jacm said:
                  @gaieus said:
                  Hi John,
                  I don't know but I'll find out. Meanwhile I'taken 2 photos with 'snipping tool'. I will try to send them in jpeg. Here's hoping.![this shows the below the "base line" as it where. Caused by unequal walls which it is hard to find, so laying the floor is a nightmare.](/uploads/imported_attachments/JhNb_Thingsunlevel.JPG "this shows the below the "base line" as it where. Caused by unequal walls which it is hard to find, so laying the floor is a nightmare.")
                  John
                  • GaieusG
                    Hi John,
                    Okay, so attaching is successful now. Unfortunately however - although as you already "know" your model, you may know that this is the problematic area - for me it is not very clear what the issue in that image is.
                    If the skp file is too big to upload here, you can also try to upload it to the 3D Warehouse (File menu > 3D Warehouse > Share model) and paste the link here.
                      jacm
                      @jacm said:
                      @gaieus said:
                      Hi John,
                      John[/quote
                      I've sent 1 photo, I'll try the other 1.
                      I don't know the size but I do know it is extremely large.
                      I think I have sent the 2nd one
                        jacm
                        @jacm said:
                        @jacm said:
                        @gaieus said:
                        Hi John,
                        John
                        I've sent the wrong one . Heres another one. I found that the lavels are uneven but when I checked the walls individually they were all 7'6" exactly but very close up they a difference in hieght even though they were built on a level plane. I'm so far into the build I don't how to fix it. When I do fix a part it moves to the next part with the same problem. Maybe I should start again?
                        JohnI got the last one wrong so I've another one to show the problem - Ihope!
                          jacm
                          @jacm said:
                          @jacm said:
                          @jacm said:
                          @gaieus said:
                          Hi John,
                          John
                          John[attachment=1:32gyf1nr]<!-- ia1 -->another level.JPG<!-- ia1 -->[/attachment:32gyf1nr]
                          I sent another which its shows up a lot better. You can see the uneven cover.[attachment=0:32gyf1nr]<!-- ia0 -->More uneven cover.JPG<!-- ia0 -->[/attachment:32gyf1nr]
                          Hopfully will be clear of the problem I've got. John
                          • chrisglasierC
                            chrisglasier
                            Have you tried viewing your model using the standard views and parallel projection? Sometimes this helps to sleuth out the problem.
                            • chrisglasierC
                              chrisglasier
                              Also have you made the walls components?
                              • W
                                wyatt
                                I wonder if parts of your model have been skewed off of the normal vertical-horizontal planes. Try turning on Color by Axis (Window/Styles/Edge). If the vertical wall lines are not blue (vertical), this could account for the small errors.
                                Wyatt
                                  jacm
                                  Never used it yet, I forgot all about it. I'll give it a try, thanks
                                  John
                                    jacm
                                    Wyatt
                                    I have pust pernt how to turn the 'paint bucket' around for part of my floor covering, i.e. 'floorboards'. I may have something to do with it as I don't think I was accurate with the 90 degree turn. I'll double check that as well.
                                    Thanks John
                                      jacm
                                      I've tried all the suggestions that have been given to me today so thanks for your input, its stopped me from going insane.
                                      I have taken yet another 'snipping tool' photo to show the problem.
                                      To recap, at the start many weeks ago I made the base, I then started to build the walls. They where doubled checked of each walls hieght and they where all 7feet 6inchestall exactly. Starting in the centre of the building, the staircase, and working out gradually building each wall and again checking the hieght. I entered each mearurement on the keyboard 7'6" and pressed 'enter' to make sure it was exact.
                                      Two days ago I came across the problem of some walls each where exactly 7'6" but when to gether there was a difference. I repaired to problem and then found another wall with a problem, this time 1 wall was 7'6" and the other was 7' 5 7/8", a difference of an 1/8". so now I keep trying to lay floors, some places O.K. but some places won't align so it becomes difficult and time wasting, makes me feel I'm going round in circles. So I ask the question dump it all and start again, (a loss of quite a few weeks weeks work). Or can somebody got a solution so that I can carry on?
                                      one wall 7ft6ins the other 7ft 5 7/8ins but they didn't start like this
                                      • Jean LemireJ
                                        Jean Lemire
                                        Hi John, hi folks.
                                        If your file is too big, first make sure that there are not a lot of textures that you may have used but that are now unused. These textures stay in the file, although they are not being used and they can add to the file size. You can purge these using the purge feature built in the Material dialog box.
                                        The same applies to components and also to layers.
                                        Or, you can do a global purge using "Menu Window --> Model info --> Statistics --> Purge Unused".
                                        If, after doing that, your model is still to big (more than 1 Meg), try this procedure:
                                        1 - Select only the part of the model that is causing the problem.
                                        2 - Copy it with CTRL-C. CTRL stands for the "control" key.
                                        3 - Open a new instance of SU (on PC) or a new file (on Mac).
                                        4 - Paste using CTRL-V.
                                        5 - Save the new model. This one shall not be too big.
                                        Without the actual SKP file, it is very difficult to diagnose your problem.
                                        Just ideas.
                                          jacm
                                          @jean lemire said:
                                          Hi John, hi folks.
                                          Just ideas.
                                          Hi 'J'
                                          I won't be able to show off my house when its finished because it will be very large indeed.
                                          I found out that I could sent a small section that may be helpful at the moment. But I will also try your method as well and see if I make it work for me, (I'll probably break it 😉)
                                          I'll sent it for a trial.
                                          Thanks John
                                          upload page.skp
                                            jacm
                                            hi 'J'
                                            I tried your method and it said that it was sucessful but when I sent it only the message went through.
                                            I did one of my 'snipping tool' I've used it today but will my house front be too big?
                                            John
                                            I'l try this one
