    More noob questions
    11 Posts 6 Posters 940 Views 6 Watching
      remus
      1. No, but it is theoreticaly possible using the 'import shortcuts' button. Its pretty easy to make your own shortcut keys, though.
      2. In reality no, but in theory you could rewrite all the tools in ruby so they dont snap. It would be a vast amount of work, though, and the overall benefits would be minimal.
      • T
        tomsdesk
        Personally, I think the ability select the snaps/inferences you want to use at any time would be an EXTRAORDINARY benefit! Just having the axis inferences toggle on/off would save me TONS! and TONS! of modeling time (by not having to zoom in close to make sure I got the endpoint instead of a reference point to it but along the nearest axis).
        2.5D Trees & Shrubs!
        • david_hD
          david_h
          Speaking of shortcuts--i am importing SU7 onto a new machine. When I import my shortcuts. . .why do they not overwrite the Default shortcuts ? Major irritation! any thoughts on this?
          • Chris FullmerC
            It is a known bug that somehow they just don't ever get around to fixing 😞
            • david_hD
              david_h
              well . . .heck. . .
              • ely862meE
                ely862me
                Since it s a noob question thread -->
                Maybe sounds hilarious for some of you but lately after saving a model the style is changing and i have to revert the style after each saving ..what s the deal,what can be done to keep the default style?
                Thank you!
                Elisei (sketchupper)
                Come and See EliseiDesign
                • Chris FullmerC
                  Interstingly enough, this thread is about keyboard shortcuts, not stlyes.
                  However, that is an interesting bug and I have an idea what might be wrong. do you have a model with an example of this? I would like to see it in action. So if you could upload a model with the style, and then tell me what it is you change in the style each time, I'll check it out. It sounds similar to another bug I found in styles that I don't think ever got fixed either. It is minor, but when it starts acting up, it can be infuriating. So post an example, I'll see what I can see (and anyone else too I'm sure!)
                  • ely862meE
                    ely862me
                    Sorry for being somehow off topic..
                    Here is a model acting like that..now it s saved with that style.After selecting the default style and saving it gets back to that style.
                    style--test.skp
                    • Chris FullmerC
                      I opened the file and it was on the default style but the style needed to be updated. I did not update it, but rather put it on to one of the default styles and then saved the model and closed it. When I opened it, it was on the style I had put it on. So I did not see anything weird. Perhaps more detailed steps?
                      • ely862meE
                        ely862me
                        This is default style-
                        After saving(the saved model keeps the default style,but the model has changed the style) i get this
                        And i have to manually reselect the default style in order to work properly at the model.
