    Move child component in dynamic component
    3 Posts 2 Posters 793 Views 2 Watching
      macumber
      I am attempting to move a child in a dynamic component through a Ruby script by setting the entity's transformation. This appears to work at first, but I get a really weird effect when I redraw (either through redraw_with_undo or using the hand icon). The objects seem to jump around, if I keep resetting the transformation and redrawing eventually it converges to the right place. Does anyone know why this is happening or a better way to move these sub components in a Ruby script(while still allowing the user to move them through the UI)? Here is my demo script and I have attached the problem component.
      Thanks a lot,
      Dan
      OpenStudio_DaylightingControls.skp
      import the component "OpenStudio_DaylightingControls.skp" and place at the origin
      select the component as the only component then run this script
      selection = Sketchup.active_model.selection
      view = Sketchup.active_model.active_view
      for i in 0..10
      puts selection[0].definition.entities[0].transformation.origin
      selection[0].definition.entities[0].transformation = Geom::Transformation.translation([0.m, -1.m, 0.m])
      $dc_observers.get_latest_class.redraw_with_undo(selection[0])
      view.refresh
      sleep(1)
      • scottliningerS Offline
        scottlininger
        Hello Dan! Sorry I missed this post. Here are two solutions to your problem. (I'm sure there are others, too.)
        1. Instead of moving the "sub" DCs with Ruby and asking the parent to redraw, have the subDCs position themselves based off of some custom attributes in the parent. You script would set these attributes, like sensor_1_x to 5.9, sensor_2_y to 25.0, etc. Then when you fire a redraw, the children will puppet themselves properly. (But, if the user tries to manually reposition them, it will ignore them... maybe not what you want.)
        2. Add a couple of more lines to you existing script...
          for i in 0..10
            selection[0].definition.entities[0].transformation = Geom;;Transformation.translation([0.m, -1.m, 0.m])
            # DCs keep track of their "last size" in some attributes.
            # This allows them to infer whether they have been scaled
            # manually by the user.
            # In this case, you are changing the bounding box of the DC
            # by moving its subparts, and so it thinks that the scale
            # tool has been applied, and is making some bad repositioning
            # decisions based on that. Doh!
            # These are the methods that the DC plugins uses to tell the DC
            # to "recalculate" its bounding box. Do this after your translation
            # and things are happier. (I can explain more if you want...)
            lenx, leny, lenz = selection[0].unscaled_size
            selection[0].set_last_size(lenx, leny, lenz)
            view.refresh
            sleep(1)
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          macumber
          Works great, thanks so much! I guarantee I would not have gotten that on my own.
          (PS I went with option 2 because the user can still move them on their own.)
          Thanks a lot,
          Dan
