    Optimization Tips
    110 Posts 22 Posters 172.4k Views 22 Watching
      Is that why each is slow?
        Guys, Thom asked if we can do something with these white spaces but I have to say it is most probable that we cannot. I is hard coded somewhere in the php script of the forum software and even if we could tweak that, it would be impossible to keep it through upgrades (which is very due soon anyway).
        Is the code tag not good (apart from that scrolling annoyance)?
          It's ok. I just hoped there was a config UI for BBCode tags on the forum. Thought it was normal. The code tag is ok, just figured if it could be changed...
          I don't suppose there are forum plugins that can be installed? having the code block apply syntax highlighting would be a delight for us coders. Such as this:
          Google Code Archive - Long-term storage for Google Code Project Hosting.
          (code.google.com)
          http://syntaxhighlighter.googlecode.com/files/Overview01.png
          Edit: what version of phpBB does SCF run? I'm looking at this: http://www.phpbb.com/kb/article/adding-custom-bbcodes-in-phpbb3/ from this it appear to be that it'd be a matter of setting the HTML replacement for the ruby tag to not collapse white space using CSS.
          Replacement sample something like this:
          <span style="white-space:pre;">{TEXT}</span>
            I can imagine you would like that syntax highlight! I use Notepad++ and know what a difference it is!
            Coen and Tavi should be spoken to about these things.
              @adamb said:
              I see a lot of SU scripts using some of the more compact iterators Ruby iterators. So they might read nice, but they're often slower than just simple for-loops.
              403 Forbidden
              (blog.shingara.fr)
              In regard to this should one init the variables used by for in to speed up things? or is that not needed?
              Would this
              ` x = 0
              for x in collection
              endbe faster than for x in collection
              end`
              • AdamBA Offline
                AdamB
                no
                  Jim
                  I've always thought for used each under the hood.
                  http://blog.grayproductions.net/articles/the_evils_of_the_for_loop
                  for loops do not have their own scope - the loop variable and any variables created in the loop become available (or are over-written) in the current scope.
                  With .each, variables are local to the block {..}
                    If you click the method names in the Ruby API manual you get to see the sourcecode:
                    http://ruby-doc.org/core/classes/Array.html#M002173
                      Jim
                      That's showing a for loop in the c language.
                        That's what it's doing under the hood.
                          Jim
                          Right, so where is the definition for the for function?
                          The answer is there isn't one because for is not a function, but is "sugar". The for loop in Ruby really uses the .each method behind the scenes.
                          Although, I can't recall where I learned that. The link to the blog article mentions it, though.
                          • tbdT Offline
                            tbd
                            speaking of each vs for :
                            loop1 = []
                            loop2 = []
                            calls = ["one", "two", "three"]
                            calls.each do |c|
                              loop1 << Proc.new { puts c }
                            for c in calls
                              loop2 << Proc.new { puts c }
                            loop1[1].call #=> "two"
                            loop2[1].call #=> "three"
                            http://plugins.ro
                            • Dan RathbunD Offline
                              Dan Rathbun
                              @jim said:
                              The for loop in Ruby really uses the .each method behind the scenes. ... Although, I can't recall where I learned that.
                              'Pick-Axe' > For ... In expressions
                              I'm not here much anymore.
                                Jim
                                I guess to get back on topic, for loops are not faster then .each iterators. The performance must have to do with how the for loop variables are not loop scoped, as in each.
                                  Came across this link:
                                  http://www.h3rald.com/articles/efficient-ruby-code-shortcut-review/
                                  On that list it says
                                  Use parallel assignment (a, b = 5, 6) where applicable
                                  while at this link:
                                  http://www.hxa.name/articles/content/ruby-speed-guide_hxa7241_2007.html
                                  Avoid parallel assignment
                                    while at this link:
                                    I just bought the ebook and that review summary was wrong - parallel assignments are not recommended for performance important tasks.
                                    Interesting read that book btw.
                                      MartinRinehart
                                      Let's see - for performance I'm going to avoid iterations, arrays, hashes and objects.
                                      What's left?
                                        @martinrinehart said:
                                        What's left?
                                        puts "Hello World" 😄
                                        • AdamBA Offline
                                          AdamB
                                          "Your racing car is not faster than my Trabant, it just covers more ground in a shorter time than my car." 😄
                                            cjthompson
                                            Has anyone looked into Enumerable.grep()? it seems pretty useful, but I don't know how fast it is.
                                            • 5 / 6
